Tail lights not working
Discussion in 'Kenworth Forum' started by drewfarmsllc, May 25, 2023.
  1. drewfarmsllc
    drewfarmsllc Light Load Member
    79
    26
    Oct 18, 2008
    South Carolina
    2020 t680 and my tail lights don't work on tractor. I have checked with a test light and no power. My backup alarm does work. They worked Monday but just quit. I have looked for fuse location and can't find any blown fuses. I checked at my left foot and under the dash. Has anyone seen this before?
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    140,811
    does the marker light work? no brake lights? or the lights dont work at all for both the marker lights and brake lights? if no power at the light with a test light, trace back where the wires go. might be to a junction box on the back of the frame there.. if you have no blown fuses, confirm that you have power to the fuse with a voltmeter or test light...if you have power at the fuse location, the problem is somewhere between there and the lights
  4. JB7
    JB7 Medium Load Member
    645
    895
    Dec 13, 2022
    Laurel, MD
    Trace the wiring from the taillights (this is the taillight harness) forward. There will be one connection to the next harness. That harness connects to the Chassis Node. Yours should be a 5 plug node, earlier models used a 3 plug node. All the lights, front or rear, go through the node. Need a wiring diagram to check input and output from the node. Node is not cheap to just throw a part at it. About $500-1k used and 1.5 to 2k new.
    Oxbow, BoxCarKidd and D.Tibbitt Thank this.
  5. drewfarmsllc
    79
    26
    Oct 18, 2008
    South Carolina
    Thank you. I will start tracing it
