T880 Engine fan wont shut off and its 36 degrees out!
Discussion in 'Kenworth Forum' started by Antwan181, Nov 18, 2018.
  1. Antwan181
    Antwan181 Bobtail Member
    7
    Nov 18, 2018
    Hello, I got a 18 T880 and the engine fan wont kick off along with 2 engine lights... I go in the cluster, and it says no warnings or faults.... before I take it to the dealer and lose the truck for days, is their a quick fix to this? T.I.A
  3. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    Manual switch on?
    Anything blocking/interfering with the fan thermostat?
    Do you have the program for that engine to change settings?
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I had this happen with a 98 Pete 377, Detroit 60
    The wiring harness had rubbed through and shorted the fuel temp sensor wire to the block. The ECM was convinced that the fuel temp was high, and commanded the engine fan to "on". High fuel temp won't set a code. Nor will other high temp indications.
    Penn Power found and fixed the problem. Charged 2 hours labor.
    YMMV.
    A side note:
    2018 is a 'new' truck. When you bring it to the dealer, you tell them that you gave them your hard earned money when there are other options available to you. And that you expect them to have your truck back to you, in good working order, when your 10 hour break is completed.
    speedyk Thanks this.
  5. Antwan181
    7
    Nov 18, 2018
    Manual switch is off... played with it countless times... nothing blocking at all... I started the truck in the morning and instantly had 2 check engine lights and the fan was going right away and never shut off
  6. Antwan181
    7
    Nov 18, 2018
    Yeah, over here in ny, the dealers suck and if your not a company with a fleet of trucks, they put you on the back burner. I checked the harness, it's fine... I just dont get it cause I was in the truck 8 hours prior, and it was running perfect. I even have a problem with fuel leaking out the cap and the ######## charged me an hour of labor to change a fuel gasket. It's crazy. The truck has 30k on it and the little issues I've had with it, KW turns the cold shoulder on almost every issue I've had.
  7. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    The Penn Power that I took the truck to was in upstate NY. Rome, maybe?
    You might be better off just taking it to someone other than the dealer and paying out of pocket. Then back billing KW directly for the repairs.
    How can they charge you for repairing a truck that's under warranty?
  8. Antwan181
    7
    Nov 18, 2018
    Yeah you might be right ... it's a shame cause you spend so much money on these trucks and they should not be having issues at all... especially when it only has 30k on it
    windsmith Thanks this.
  9. speedyk
    1,837
    2,470
    Apr 8, 2015
    The more time I spend around Paccar trucks, the more I think they hired away some electrical engineers from Audi. Far too much "nice stuff" and not enough attention paid to critical stuff. I don't need the radio turning itself on and turning the volume up every time I start it.
  10. Matt43324
    Matt43324 Light Load Member
    218
    175
    Jun 1, 2014
    Does your cruise control work by any chance? Because two weeks ago I ended up leaving a few cab lights on in the CB during my 34, come out Monday morning start getting everything ready and I realize every freaking light in the dash was on and the fan clutch stayed engaged. Shut off about 10 minutes turn it back on everything fine. Guessing it was just low voltage
  11. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    You have to buy 50 or more to even get their attention.
