So when I first got the device I was able to delete logs that weren't driving time. Such as deleting a log where I wanted to delete the log with annotation. Now I can only add or edit the logs. Was this a system update or the administrator/company I purchased it through disabled this function?
I wouldn't be surprised if crst Malone did this so they can monitor your every adjustment of logs.
T7 transflo
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by TakinItEasy, Dec 18, 2017.
I’ve been editing mine except it won’t let you edit driving time. I’ve not tried to delete a log because if there’s no driving it becomes off duty time.....
TakinItEasy Thanks this. -
Right mine too, but I had to go back and change the on duty time of day. It took it OK.
I’ve got the wrong information in the Company Name and address and can’t change it.....
Also be careful when you are in a bad service area and make a change to your logs it will not save that change. It will revert your change to its original status. This happened to me and it showed me being on-duty for 10 hrs while in sleeper. I started driving and finally got cell service. Shortly after I received a message alerting me to a HOS violations of driving after 18 hours on duty lol!
Yep I saw something like that and learned to watch it real close........
I have that privilege but it can’t be changed through the portal......been sending trouble tickets and calling support # but so far can’t get a hold of them......
Jet A Fuel Thanks this.
