t660 No heat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tama Mai Hawaii Nei, Nov 20, 2016.
  1. Tama Mai Hawaii Nei
    Tama Mai Hawaii Nei Light Load Member
    296
    127
    Sep 6, 2013
    Las Vegas, NV
    My Kenworth has no heat cab or sleeper.
    Dash switch seems to work I get ice cold A/C and not so cold air on the hot side.
    Checked fuses and relays all seem fine. Coolant level is full.
    I did notice coolant lines on passenger side of engine are cold. No leaks to point me towards heater core.
    Any ideas or suggestions on where to look next.
  3. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Shut off valves?
  4. Tama Mai Hawaii Nei
    296
    127
    Sep 6, 2013
    Las Vegas, NV
    I did not see any. That was one of the first things I looked for. I had 2 on my N14
    Engine is a Paccar if it makes any difference.
  5. Ridgeline
    22,116
    113,355
    Maybe you have a bad heater valve?
    Tama Mai Hawaii Nei Thanks this.
  6. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    If it's full of water and there's no shut off valves, it's gotta be the heater valve. Or the cable that open it. I'm not familiar with that truck, but the system is simple. Something is keeping the coolant from flowing.
  7. Tama Mai Hawaii Nei
    296
    127
    Sep 6, 2013
    Las Vegas, NV
    Imma have to wait until light to find that valve. I been working on it out in the parking lot.
    I believe I know what valve your talking about. It's on passenger side of firewall hopefully I can either bypass it for now or get it working.
  8. Ridgeline
    22,116
    113,355
    It is usually closests to the heater inlet on the firewall. I had a isx that had the valves moved at the factory to add something to the engine. They put one valve almost behind turbo and the other one was at the firewall just before the heater valve.
  9. Aron
    Aron Bobtail Member
    33
    16
    Nov 13, 2016
    My t800 had same problem turned out was the heater valve darn thing had little arm broken off on it good luck!
  10. AModelCat
    154,582
    Likely the water valve. Hopefully the heater core isn't plugged up internally.
  11. Tama Mai Hawaii Nei
    296
    127
    Sep 6, 2013
    Las Vegas, NV
    Finally got it fixed... Heater control valve on fire wall was plugged.
    I went to take it off and black soot was all inside clogged everything up.
    After cleaning everything out heat works like a charm.
    I appreciate the advice on where to look
    RubyEagle, GrapeApe and ShooterK2 Thank this.
