I had this question asked to me today, I don't know the answer to so ill ask you guys
If someone changed from 24.5 Low Pro tires to 22.5 Low Pro tires without changing the speedometer, will the truck go faster or slower. Our shop mechanics are saying it will go faster where the driver is saying slower. I have no idea so id really appreciate the help
thank you
Switching from 24.5lp tires to 22.5lp
Discussion in 'Ask An Owner Operator' started by RunFlat, Jan 1, 2015.
Page 1 of 3
Bigger tires to smaller tires, the speedometer will read faster than your actual speed...which makes a governed truck slower. Changing from smaller tires to larger tires causes the speedometer to read slower than actual speed.
Think about it. The "speed sensor" on the back of the transmission only counts the revolutions of the drive shaft. Anything you do that alters the distance traveled per revolution of the drive shaft is going to make your speedometer less-than-accurate one way or the other. Larger tires cover more distance per revolution of the axle than smaller tires...3.55 axle ratio turns the axles around more times per driveshaft revolution than a 4.10 axle ratio would.
In any case, more ground covered by the same number of revolutions of the drive shaft = faster speeds than the speedometer shows. Less ground covered = slower speeds.RunFlat and Lone Ranger 13 Thank this. -
Why would you switch?
The simple explanation is that your speed is counted by revolutions of the tire or drive shaft. (Like PB said.). It's never based on how fast you're actually moving.
Take a quarter and nickle and color the edges with a marker. Run them across a sheet of paper for the same amount of revolutions. The nickle's trail will be much shorter than the quarter. It's the same principle with your tires. They'll be going the same speed according to your speedometer, but you'll covered distance.
Good way to prove your mechanic wrong!
tl;dr
The smaller the tire the slower you'll go. -
Wont it throw the speedometer and odometer off if you change the wheel/tire size from factory or am I not understanding that correctly? I wouldn't want to do that even if I had a preference for one size wheel or another.
Yeah, why would you want to go to a smaller size? Does it have anything to do with tire availability, cost,etc? myself I'm looking at doing the opposite. To answer the question the actual distance covered will be less than the odometer shows.
You just change the calibration so it's accurate. ECM parameter change that isn't hard.
JJ 501, Cetane+, double yellow and 1 other person Thank this. -
I think 24.5's look cooler but I cant tell any difference in ride quality or performance like some guys claim to. Of course I've never switched from one to the other on the same truck so maybe I don't know what I'm talking about. -
When you switch from smaller to larger your speedometer will be slower than your actual speed. When going from larger to smaller the speedometer will read faster than your actual speed.
Page 1 of 3
