Swing doors vs roll doors?
Discussion in 'Refrigerated Trucking Forum' started by scoobertdoo, Jul 13, 2021.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,601
    Nov 11, 2020
    I have always had swing doors, but so many reefers are roll doors. I've never even been asked what door type I have. Do all or most places allow roll doors?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,697
    Mar 30, 2014
    Roll doors have a lower clearance than swing doors. I tried to load at a place and they couldn't put the product in the door!
    Forget it! Pull a flatbed instead.
  4. scoobertdoo
    1,512
    2,601
    Nov 11, 2020
    This is the reefer truck section. We don't load super high cold ####, it wouldn't stay cool. And we earn more than flatbed.
    bzinger Thanks this.
  5. Chinatown
    Chinatown Road Train Member
    73,251
    164,557
    Aug 28, 2011
    Henderson, NV & Orient
    I've pulled roll door and swing door.
    Some places won't load a roll up door for the very reason @Bean Jr. posted.
    Double stacked pallets sometimes won't clear and you're not allowed to down stack.
    bzinger and Bean Jr. Thank this.
  6. Peter_Bilt
    Peter_Bilt Light Load Member
    84
    54
    Feb 18, 2017
    The only people you see with roll ups are larger companies who do P&D.
    Bean Jr. and Speed_Drums Thank this.
  7. Bean Jr.
    5,467
    9,697
    Mar 30, 2014
    It was a joke, son!
  8. 201
    201 Road Train Member
    12,047
    24,587
    Apr 16, 2014
    high plains colorado
    I've pulled both, roll up the way to go. Any company that values their drivers, gives them roll up doors. One reason reefers are roll up, is a lot of cold air is lost just backing in with swing doors and with drivers backing skills today, it would all melt. Swing doors add width backing in( never saw anyone take off a roll up door) and you figure how many times you get in and out with swing doors, setting brakes, etc, roll up the way to go. Funniest thing with roll up doors? When someone drops a trailer in a dock with swing doors thinking it was a roll up,, :thumbup:
    RockinChair and Bean Jr. Thank this.
  9. kemosabi49
    10,435
    44,384
    Jan 13, 2013
    SW Arkansas
    Many retail companies like WM, Target etc use roll up doors so the trailers can be dropped in the store's doors with the seal intact. But the roll up door trailer does limit height and to a certain extent width at the point the door comes down.
    REO6205 and Bean Jr. Thank this.
  10. scoobertdoo
    1,512
    2,601
    Nov 11, 2020
    What I am trying to work out is if it would be a massive detriment to my business if I had one. I don't want to be turned away from 1 of 10 loads because I have a roll door. 1 of 1000 would be acceptable.
    Bean Jr. Thanks this.
  11. slow.rider
    slow.rider Road Train Member
    2,005
    4,740
    Apr 4, 2017
    NYC
    I also figured roll up doors were more for local work, multi stops per day. Less time spent docking but not nearly as well insulated against temperature and water.
    If you've ever seen those UPS pups with the clear plastic sticking out the bottom of the door and blowing around, the reason they put that plastic in there is to keep the water that leaks thru the roll door from getting onto the cargo.
    D.Tibbitt, wis bang and Bean Jr. Thank this.
