Swapping rims? 2 piece lug nuts to 1 piece lug nuts?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lazer, Aug 7, 2021.
  1. Lazer
    Lazer Road Train Member
    1,821
    2,904
    Jan 22, 2017
    I know, an odd topic.
    1995 T800, rims all around have the style for the 2-piece lug nuts. All the spare rims we have use the 1-piece(or single) lug nut.
    How difficult would it be to change the steering wheels, to the single lug nut style?
  3. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    Budd wheels switching to unimount will take new hubs with studs and lug nuts. Most likely will need drums too.
  4. Rideandrepair
    17,422
    56,523
    Aug 8, 2015
    Might as well get the whole hub kit, with races already installed and new bearings. And the Longer studs for aluminum rims. Will be nice anyway, all new seals and bearings, on such an old Truck. Good peace of mind. Slap on new brakes while you’re at it. I’m guessing $1200 at least for all 6. Plus brake shoes. Probably more. I’d call around for prices. Lot of different pricing out there.
  5. Goodysnap
    3,744
    9,105
    Jul 12, 2017
    Your right.....
    Conmet come loaded and even have the seal in them, ready to bolt on. If its a high mileage truck the bearings proly look like crap anyhow.
  6. Lazer
    1,821
    2,904
    Jan 22, 2017
    The truck has 1,083,000 mi. Have plenty of tires on other aluminum rims, for now I will just swap rubber. Once we get this truck inspected, licensed, and discover how it works doing local deliveries, we may make the change then. Thanks for all the replies.
    Rideandrepair and Goodysnap Thank this.
  7. Big Road Skateboard
    6,641
    37,254
    May 2, 2021
    I swapped it all on my 92 Volvo before I put it on the road. I hada salvage truck with hub pilot hubs on it, so I just swapped it all.
    Can be tough to find Budd wheels, even nuts and thimbles anymore.
    Rideandrepair, Bean Jr. and Stray_Dog Thank this.
  8. Lazer
    1,821
    2,904
    Jan 22, 2017
    I may not have described what I have correctly, all the rims we have are 1-piece. No split rims. All the rims we have, only require 1 lug nut. The rims on this one particular truck, has the 2-piece lug nuts on the drives. You know the kind, mount the inner on the axle, drive on the lug nut, then put the outer tire and rim, then drive on the larger outer nut. These type of rims have a slight ‘counter sink’ or bevel for the outer nut to tighten down into. None of our spares, or other trucks have these particular rims.
    Rideandrepair Thanks this.
  9. Goodysnap
    3,744
    9,105
    Jul 12, 2017
    You desribed it fine,
    You have Old school Budd wheels which are stud pilot or stud centered wheels. To upgrade you need to change hubs to change to Hub piloted wheels with the washered single nut.
  10. Lazer
    1,821
    2,904
    Jan 22, 2017
    Ok, thanks. Then, what are the old, old style called with the ring between the duels, and the five lug nuts with the wedges, are those called ‘Dayton’ style rims?
    Goodysnap Thanks this.
  11. God prefers Diesels
    4,198
    22,262
    Jun 26, 2020
    South Texas
    Yes.
    Also, @Ezrider_48501 has a series on YouTube rebuilding an old Pete. There's a video where he swaps from stud pilot to hub pilot. (what you want to do) So you can get a good idea of what you're looking at. It's not hard. If you're tooled out good enough to change a wheel seal, you can do the swap.
