Swapping cab lights from square to bullet style
Discussion in 'Peterbilt Forum' started by TWC, Feb 9, 2016.
  1. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    Can I just unbolt the square cab lights on my 1997 379 and replace them with the bullet style? Or do they need new mounting holes?
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,697
    Mar 30, 2014
    Need new mounting holes, but a friend and I changed in about an hour. What a change! The truck looked 1000 times better with bullet.
    Cottonmouth85 Thanks this.
  4. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,700
    May 3, 2012
    Floresville, Tx
    Yup, the front holes work, the back ones... not so much. Get yourself a tube of clear drying caulk while you're up there and be careful drilling that fiberglass.
  5. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    My roof cap is aluminum. So use the front mounting holes and drill new ones for rear?
  6. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Silicone will eventually fail, I would glass or bondo and paint the old holes.
  7. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    I'm going to jb weld the holes left and the holes for the air horns. Adding 2 cab lights as well. I have read a few people did the jb weld and then body work and paint. Since most of the paint is gone on my roof anyways.
  8. 59MackB61
    59MackB61 Light Load Member
    196
    165
    Sep 12, 2012
    If you are going to body work it use automotive epoxy if you are just going to fix up for now I would use seam sealer or a quality exterior silicone that is uv protected. I would silicone under the the lights were the wires come through the roof cap.always do it from the top side to make sure it keeps the water out.
  9. flat top
    flat top Bobtail Member
    44
    25
    Jan 28, 2010
    Colby Ks
    This is a project that's on my to do list as well. Do any of you know which lights are the absolute brightest? There seems to be a couple of styles, with varying number of led's.
    Thank you.
  10. TWC
    TWC Bobtail Member
    15
    Mar 18, 2014
    I haven't been too big on the led cab lights. I always liked watermelon glass lense with an 1157 bulb. But that was 15 years ago.
  11. 59MackB61
    196
    165
    Sep 12, 2012
    Check out slc lighting very affordable and oem quality just bought new bullets for my girl, really nice looking jewlery.
    Cottonmouth85 and baha Thank this.
