Swap out air to electric wiper motor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Waterman1000, Oct 3, 2010.
  1. Waterman1000
    Waterman1000 Light Load Member
    50
    Jan 18, 2009
    Some of you may have the same problem. I have a '69 White FreightLiner COE. The air wiper motors drive me nuts. Some times they work, in a spastic way, some time they don't. I would like to know if there's a " bolt on
    replacement " 12v electric motors. I've been looking at the universal ones for cars/trucks.
  3. pudamobile
    pudamobile Bobtail Member
    27
    5
    May 31, 2010
    Cooperstown, ND
    I'm thinking the same thing with my '87 T-600, the air motors are leaking like a sieve and no air motor is a good motor. Will be following this thread closely!
  4. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
  5. billandlori
    357
    107
    Sep 5, 2010
    Check some hot rod shops, not sure how durable they would be.
    Check out Summit Racing and seach for AutoLoc Heavy-Duty Power Windshield Wiper Kits.
    I posted a link, but I guess that won't work....
    Bill
  6. Mastertech
    Mastertech Staff Leader / Admin Staff Member Administrator
    117,207
    29,304
    Dec 28, 2007
    3rd Rock From The Sun.
    It worked, it just was waiting on a mod for approval for some reason.
    billandlori Thanks this.
  7. Waterman1000
    50
    Jan 18, 2009
    Checked out the kit listed in the above link. Interesting, but what I'm looking for is a wiper motor thats self contained. It would wipe back and forth. Don't have room for cross bars. I belive In the KISS principle. The passanger side air motor started to behave again.... But drivers side is dead now. Again.. Some days I feel like drilling a hole thru and mounting a handle... I'm now looking at the drivers side dash wondering how much I'll have to disasemble, to get to the motor, moan....
  8. BrainHurtz
    BrainHurtz Light Load Member
    245
    57
    Jun 24, 2008
    Terre Haute, In
    How you tried looking for parts from trucks with electric wipers?
    The Kenworth B-Cab hasn't really changed all that much mechanically in the last 20 years...
  9. billandlori
    357
    107
    Sep 5, 2010
    If you don't care about them wiping in sync, you could check out fork lift wipers or even tractor wipers at TSC or Farm&Fleet.
    Bill
  10. Bush chook
    Bush chook Light Load Member
    144
    43
    Apr 27, 2009
    Geelong
    Over here we use a rear wiper motor off a General Motors station wagon , one speed but it,s in between your old two speed wiper set up so it,s quite good - mounting is not a problem on a kenworth as you can utilize the old air cylinder mounting bracket , shaft length is the same as air cylinder and your wiper arms bolt straight on only problem is you have to mount two motors , Paccar do sell a conversion kit but it costs -
  11. Waterman1000
    50
    Jan 18, 2009
    What year on the GM station wagon. I'm going to stick my head up under the dash this weekend to see how much of a pain it's going to be getting the old one out. I'll try and document what I'm doing with text and pic's. I had the same idea. If I can find a motor that close to the mounting holes with same lenght and shaft dia as the wipers, it could work. As to speed, as long as it's not going like a bat outa hell. Just need to wipe the water off.
