suspension dump switch
Discussion in 'Western Star Forum' started by cootr68, Dec 29, 2013.
  1. cootr68
    cootr68 Light Load Member
    185
    53
    Jul 25, 2012
    central il.
    My dump switch on the dash is leaking air it's the switch itself. If I block off the lines will the airbags work as normal going down the road until I get a new switch? Or will they deflate and not re inflate?
  3. killroy
    killroy Light Load Member
    222
    155
    Mar 30, 2008
    Kenner, La.
    Something I've never thought about, but I would say if you disable it by blocking it off bags should work normally as if you did not have a dump in the first place. In other words give it a shot.
    cootr68 Thanks this.
  4. cootr68
    185
    53
    Jul 25, 2012
    central il.
    Not blocking of the bags just the switch at the dash.
  5. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    The way a dump switch works is to send air pressure to a port on your leveling valve that exhausts air from your bags. If you never supply pressure to that port, it will function normally.
    cootr68 and KW Cajun Thank this.
  6. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Cetane+ beat me to it. Blocking the switch line will make them operate normal, and no loss (dumping) of air.
    Cetane+ and cootr68 Thank this.
  7. cootr68
    185
    53
    Jul 25, 2012
    central il.
    Sorry read your post wrong. Thought that you said blocking off the bags, but reread it and that's not what you meant.
  8. killroy
    222
    155
    Mar 30, 2008
    Kenner, La.
    No I did not mean block the bags, I was still on my first coffee, and forgot a comma, amazing the difference they make. LOL
