Super Star 120 FM info?
Discussion in 'CB Radio Forum' started by BigByrd47119, Jan 11, 2013.
  1. BigByrd47119
    BigByrd47119 Light Load Member
    86
    21
    Jan 3, 2013
    Havnt found ANY info on this radio. Apparently it is an import (or so the guy that gave it to me said). SSB, hi/low power (whats that?), Am/Fm (whats the fm for?), etc.
    Came with an Astatic mic that I threw onto the Cobra for now until I learn more.
    Thanks for any help!
  3. kc0iv
    kc0iv Light Load Member
    294
    233
    Mar 31, 2010
    Parkville, Mo
    google in your friend
  4. kor b
    kor b Light Load Member
    254
    103
    Dec 16, 2008
    Export is the proper term.
    SSB is single side band
    Run it on AM not FM
    Select D for CB channels.
    BigByrd47119 Thanks this.
  5. BigByrd47119
    86
    21
    Jan 3, 2013
    Came upwith a bunch of foreign sites.
  6. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    I'll clarify for you....
    AM and FM are the "modes". SSB is another mode.
    FM is used in ham radio. As is SSB, but CB also uses SSB, sometimes. SSB is only good if your trucking cohorts also have an SSB radio. Otherwise keep it on AM.
    Hi/low power just adjusts the dead key. Run it on high if you're running barefoot (no amp) or low (if you are going to run an amp) Keep in mind the legality issues with running amps on CB.
    Also agree....band switch, find out which one gets you on the CB band and leave it there....flipping the band switch around gets you on the ham bands....last thing you want is a fine for unlicensed radio operation.
    Is this the radio you have? It doesn't look like it has SSB....
  7. BigByrd47119
    86
    21
    Jan 3, 2013
    Exactly what I was looking for!
