Super single tires vs dually tires
Discussion in 'Experienced Truckers' Advice' started by Lonewolf2000, Nov 5, 2017.
  1. Lonewolf2000
    Lonewolf2000 Medium Load Member
    310
    322
    Nov 5, 2017
    New York
    I’m new to trucking so I would like to know from the more experienced guys what are your opinions on super single tires. The good , bad etc.
  3. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    Easy to chain in the winter. Their chains will run you $100 more than singles. Other than that, I don't like them. Once they're flat,you are stuck on the side of the road unless you want to chain up your axle.
    Lepton1 and bigkev1115 Thank this.
  4. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I've not ran them since they first came into the mainstream of trucking probably 10+ years ago. I did not have any issues with them then, one way or the other. But it seems they wear faster than they're supposed to. And it seems many large fleets who tried them for many years, have since moved away from them so that should tell you quite a bit.
  5. againstthewind
    againstthewind Road Train Member
    2,027
    3,164
    Oct 26, 2012
    the good is apparently they are lighter, the bad is everything else.
    Just passing by, Lepton1 and Kyle G. Thank this.
  6. Lonewolf2000
    310
    322
    Nov 5, 2017
    New York
    Just from looking super singles they don’t look like they would grip the road as good in slippery conditions. I thought I read somewhere on the web someone said they provide good traction in rain/snow/ even ice. But someone else said they suck in any kind of inclement weather. I don’t know what to believe.
    okiedokie Thanks this.
  7. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,159
    Oct 2, 2011
    I've ran them on two different company trucks and thought they were terrible. Wether its just from rain or snow I felt very unsafe. Truck would slide a lot. Running them off roading when I hauled trash was a disaster also. They would constantly get drivers stuck at the landfill on dirt, rocks, mud etc etc... As a Owner Operator now I wouldn't even consider them.
  8. haz-matguru
    haz-matguru Road Train Member
    2,866
    4,338
    Feb 18, 2012
    SS are the stupidest ideas in trucking next to auto Trans, cameras, micro management, and twerp face dweebs in management.
    "But I graduated from Purdue I deserve a management position with my degree field". So what pepsquek I rebuild Cummings with my eyes close. And I didn't go to skool Fer it either!!!
  9. Tall Mike
    Tall Mike Road Train Member
    7,246
    33,746
    Aug 20, 2014
    New York State
    Singles are terrible in the snow, never tried chaining them so I can't speak if they get better in the snow with chains.
    Never had any trouble with singles in the rain but I knew to take it easy with them.
    Steel Dragon Thanks this.
  10. supersnackbar
    18,602
    44,735
    Aug 19, 2007
    Your Town, USA
    I used singles, had good luck in moderate snow as long as I was loaded, empty was tricky. I live on a dirt road and would almost get stuck if my tires only lost traction slightly.
    As far as flats, many times if you get a fast flat or a blowout, many times the wheel has to be replaced as well because the sidewalls aren't strong enough to support the weight at that axle position, and most SS tires are mounted on aluminum wheels, and it doesn't take much to get damaged beyond use after a blowout.
    Steel Dragon and Lepton1 Thank this.
  11. haz-matguru
    2,866
    4,338
    Feb 18, 2012
    Yea ss suppose to save money. But once there's a flat or blowout at Hiway speeds. The rim and tire will be any where from 2300-2700.
    So you just paid all the money you supposedly were saving.
    SS are stupid!!!
