super 10 eaton fuller question
Discussion in 'Freightliner Forum' started by chimbotano, Apr 4, 2014.
  1. chimbotano
    chimbotano Heavy Load Member
    747
    1,058
    Apr 21, 2013
    can anyone tell me the pros and cons in comparison with regular 10 or 13 gear trany? I've never driven this type of transmission and I was wandering if this "super 10" is different or if there is anything special....why is this trany called "super 10"
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Super 10 is the best of the 10 spds in my opinion. Shifting it is like driving the high range of a 13 and splitting every gear. There is no fingertip range selector, that function is done on the trans when you move the shifter from 5/6 to 7/8 hole. Each hole is 2 gears and selecting is done with a thumb switch like a 13 or 18. Upshift in each hole is lift throttle and it drops in the next gear. Downshift is lift throttle then roll back in to raise rpm. Exactly the same as splitting a 13/18.
    Pros... once you get used to driving one you can slip through the gears faster and smoother than any other manual gearbox.
    Cons... its not a 13/18 so you still cant drop half a gear when that would be an advantage. Only other thing I can think of is having to listen to joe supertrucker tell you how bad a super 10 is because he couldnt get the hang of it.
    Possible con.... theres a variant called the Super 10 Top 2. The Top 2 gives control of the 9/10 shift to the engine ecm. It SUCKS. Luckily that function can be disabled in the ecm.
    chimbotano Thanks this.
  4. Dickeyroberts
    Dickeyroberts Light Load Member
    138
    30
    Feb 23, 2014
    Super 10s are awesome! My favorite by far! Their really nice in traffic because your only physically shifting the truck 5 times instead of 10. Only negative thing is that their lazy. If you get on throttle to early gears won't catch. Other than that there is not many negatives to them
  5. blairandgretchen
    13,238
    70,566
    Dec 9, 2011
    South west Missouri
    I liked them, for all the above reasons.
    Agreed on the top 2 super 10 . . .
  6. mgrantes
    mgrantes Light Load Member
    111
    30
    I've driven one too and Loved it and it doesn't take long to get the hang of it. The shift points are pretty much the same as a regular 10spd and downshifting is way easier. I've no idea why these things disappeared
  7. Red Rocket 1964
    Red Rocket 1964 Light Load Member
    115
    44
    Jan 31, 2013
  8. Boise's Trucking
    Boise's Trucking Bobtail Member
    Anyone have any ideas why my super 10 eaton is winding real bad mostly while loaded, checked all the mounts and trans fluid is full, does it off and on in all positions, only when it warms up to operating temp, sounds like its going to come apart when it does it
  9. Diesel Dave
    8,531
    23,591
    Jan 20, 2010
    Hesperia, Ca.
    I'm taking a guess, but sounds like the bearing are going out. If you want a temporary patch, throw some Lucas addictive.
    Boise's Trucking Thanks this.
  10. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    maybe it don't have any oil in it
  11. ironeagle2006
    ironeagle2006 Road Train Member
    Have your back end sychro checked out in the transmission. At about 1 Million or so miles they start to wear out in the Super 10 regardless of what you do to keep them going. Rebuild the transmission and your good for another 1 million.
