Sulphur smell from battery box
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Patriotleasing, Apr 16, 2023.
  1. Patriotleasing
    Patriotleasing Bobtail Member
    28
    Jan 1, 2017
    Every once in awhile I get a whiff of sulphur from the battery box. Tested all 4 batteries independently and they're all at or over 14 volts. What say you?
  3. Opus
    114,769
    Your batteries are going bad
    InTooDeep, Diesel Dave, 2Tap and 6 others Thank this.
  4. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Alternator could be over charging.
    Cables shorting causing batteries to overheat.
    Or, What opus said.
    W923, Magoo1968, ducnut and 2 others Thank this.
  5. AModelCat
    154,360
    How are you testing the batteries? If they just came out of the truck after running a while or off the charger you've got to pull the surface charge off first before testing. 100 amp load for a few seconds, let them recover a few minutes then load them up to half the CCA rating for 15 seconds. If they recover to 14 volts a minute or 2 after the load test they're definitely shot. Any smoking cells during the test they're shot.
    Batteries generally do not boil over until about 15.5 volts IIRC. If they're boiling at normal charging voltage (13.5 - 14.5 volts) chances are the batteries are on the way out.
    Bean Jr., Diesel Dave and Hammer166 Thank this.
  6. Hammer166
    7,347
    26,368
    Aug 18, 2007
    ~8600+' and loving it!
    If you're smelling sulfur, you should be able to find the bad battery easily. Look for a swollen battery case, or feel for a hot battery after the trucks been running a while.
    @AModelCat posted the proper full test procedure, but if one's already bad, it doesn't take that much to find it. Even one of those handheld load testers will let you find batteries getting towards the end of life, the voltage drop under load is much greater than a good battery.
    Jubal Early Times and Diesel Dave Thank this.
  7. xsetra
    5,094
    6,941
    Aug 21, 2011
    Don't forget your safety glasses working with batteries.
  8. Big Road Skateboard
    5,691
    29,648
    May 2, 2021
    Absolutely. I've had several blow up during load testing.
    Got nothing else that@AModelCat didn't mention.
  9. MacLean
    MacLean Road Train Member
    1,268
    3,716
    Sep 12, 2017
    Once they start off gassing they’re toast. And voltage test isn’t the way to check, you need to load test them.
  10. AModelCat
    154,360
    I'd even add in a faceshield, maybe have a garden hose handy if one blows its top. You'd want that acid off your skin as soon as possible. That gas is flammable so you need to wait until they're done gassing before removing any cables. One spark and its Hindenburg 2.0 right in your face.
  11. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Shoot all batteries at the base with temp gun. The sulfated one will be warm or even hot to the touch compared to the others.
    Bean Jr., FLHT, Mnmover99 and 4 others Thank this.
