Stupid Question on Freightshakers
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ChromeDome, May 20, 2010.
  1. ChromeDome
    ChromeDome Road Train Member
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    Ok, this will sound really dumb but I have wondered for a while.
    I will start by saying that the only Freightliner product I have ever driven is an FLD.
    I was just wondering what the real differences are between a Columbia and a Century?
    I can see a difference in headlights, but that is about it.
    I have seen several people say in this forum in different threads that that they would drive a Columbia but not a Century, but I have no clue as to what is different.
    Tried looking at freightliner sites etc, to no avail.
    Thanks for any feedback.
  3. Injun
    Injun Road Train Member
    8,501
    9,491
    May 15, 2010
    West o' the Big Crick
    Exterior body shape: The hood and fenders are more round on the Columbia and the hood latches differently. Also, even though they are both Freightliners, the Columbia, in my experience, is better quality and more driver-friendly. There are also some differences in the dash setup.
    The interior cabinet configuration is virtually identical.
  4. LostinOregon
    LostinOregon Bobtail Member
    37
    Apr 2, 2010
    Siletz Or
    If its a Freightliner, the cup holders suck.
  5. johnday
    johnday Road Train Member
    I could be wrong, but wasn't the Columbia supposed to be a cheaper Century?:biggrin_255:
  6. OJTTrucker
    OJTTrucker Bobtail Member
    29
    11
    Nov 28, 2009
    Granny Lane
    I agree. In all the yrs FL has been designing trucks, you'd think they could comeup with a cupholder that fits........ something!! :biggrin_25510:
  7. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Columbia is a toned down Century....side fairings, headlights, and the interior package for the Century has more options. but no more Centuries...replaced with Cascadia...basically identical except for some aerodynamic changes and newer options inside.
  8. Allow Me.
    10,642
    12,108
    May 28, 2009
    Rancho Mirage, Ca.
    When the Cascadia was introduced, there was a lot of fanfare from Freightliner about millions spent on research BEFORE they built it. So I ask you, why no locking fuel caps as standard equipment? Why no sun visor in the middle of the windshield? An adjustable slot for anysize CB? Larger guages? Larger switches and not so close to each other? Better vents? Windshields that don't leak? A beeper/chime to let you know the turn signal is still on? A more anti-theft ignition key system? Better side mounted turn signals? An intergrated built-in APU type set up for heat/AC?
    RAILSPLITTER Thanks this.
  9. Injun
    8,501
    9,491
    May 15, 2010
    There is a built-in HVAC system available for Cascadia...it's the battery powered kind. It runs off its own batteries (4,6 or 8 ) and will run you out with either the heat or the AC. It adds about 8K to the cost of the truck and about 400 pounds. The beauty of it is no fuel use at all, no emissions. It charges as you drive and if the charge gets too low while you're sitting the engine will automatically start and charge up the batteries.
    Cascadia also has a lot more insulation than Century did. Those old Centuries and Columbias would get so hot inside because of the exhaust system and running gear under the floor it took hours to be able to stand it in the truck if you weren't idling it. Cascadia isn't like that at all. The floor doesn't even get warm, much less hot. The ride is quieter, I love the rack n pinion steering...too bad I can't get that on Columbia.
  10. johnday
    When did this happen? SNI is still getting 2010 Centuries. I wonder if it's some sort of contract thing or something? Maybe for model year 2011 the Century is gone?:biggrin_25525:
  11. LostinOregon
    37
    Apr 2, 2010
    Siletz Or
    I have always said Volvo is better for driver comfort.
