Stud pilot studs
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Jun 12, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I have a set of 40,000 lb Rockwell rears
    I don't have any of the studs and lugs to attach the wheels. I am only looking to attach the inner wheel.
    What is the proper term for that part? Are there different sizes?
  3. TGUNKEL
    TGUNKEL Light Load Member
    229
    160
    Mar 16, 2013
    Spokane,Wa
    Thimbles. As far as I know there is only one size.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I am not sure what you are saying. The hub pilot studs use the same nut to attach one wheel or two.
    Does your hubs have studs in them?
    If they are bud studs, you will need bud inner nuts, and the right ones, they are different for steel and aluminum.
    BoxCarKidd Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Stud mounted "Budd" wheels are 3/4"-16 inside and 1-1/8"-16 outer. Barrell nuts hold the inner wheel on. Regular nut on the outer. RH side are RH thread and LH side are LH thread as stamped on the fasteners. As @starmac says, if you are running aluminum wheels you will need to get the longer barrel nuts with the stepped shoulder.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Do not forget Budds have LH studs on the left and RH studs on the right. When we put single floaters on the rear drives we use nuts for the steer axle.
  7. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Are you saying you use 3/4-16 budd nuts to put single wheels on the drive inner studs without the barrel nut? Sounds like it would work if I read you right. Any issues with loosening? Most steer axles are the larger 1-1/16 tapered nuts.
  8. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    To use a regular steer axle nut, you would have to use an inner nut first. I have some nuts that work, not sure what I have them for or when I even got them.
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Hmmm...... guess I was thinking if the inner nut went on without a wheel there would be a gap. Retired my pork chop years ago.....lol.
    spsauerland Thanks this.
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Had some earlier 90's Heil blow cans that ran Super singles (425/65R 22.5 on 12.25 wheels) with stud pilot hubs. The nut was a one piece 3/4" with a very deep shoulder sleeve to center them up. Drivers always complained about not having any stud standout. Finally put longer studs on them to appease them.
    wore out and BoxCarKidd Thank this.
  11. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Seems like stud piloted wheels were always extremely over tightened with 1" impact. Seems like we always had broken inner studs during wheelend maintenance as a kid.
    snowman_w900, wore out, swaan and 2 others Thank this.
