This clears up a lot . It means I dont need the other harness that goes to the ecm . The power comes up the shifter but it doesn't go down the air solenoids . I will change the harness from the shifter to the air solenoids and see . Another concern I have is the neutral switch . I didnt buy it . Will pick one up from the junk yard .
Stuck under a load.10 speed Meritor Transmission will not go into high
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by henboy1, Feb 20, 2020.
Page 2 of 3
Anyone know of a shop in Phoenix that's good with Meritor 10 speed?
Another Canadian driver Thanks this. -
I'm having this same issue in my 03 classic. It grinds going low to high and back again but sometimes it won't go to high at all. When I flip the lever back to low it grinds going back to low. From what I've gathered it sounds like my high side solenoid is going out correct?
Another Canadian driver and Lysdexis Thank this.
Another Canadian driver and Rightlane76 Thank this.
Another Canadian driver and armo Thank this.
i had this problem before... it was wire problem
Page 2 of 3
