stuck slack adjuster
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DL550CAT, Jun 5, 2010.
  1. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    anyone have any slick tricks for removing a frozen slack adjuster from the s cam?
  3. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    heat is a wonderful thing but have a fire ext. close by when the grease catches fire. not really to cut it off but the heat expanding and contracting will do amazing things. brake clevis pins are a great example. no real way to grip them to put enough torque to loosen them. heat the clevis and she will turn by hand. hope this helps. johnny
  4. DL550CAT
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    thanks for the reply but I am having trouble with the slack to cam spline dont really want catch the grease on fire right next to the air bag
  5. upallnite
    upallnite Light Load Member
    165
    115
    May 15, 2010
    Hempstead,TX
    they use a tool like that looks just like tie rod remove tool it has tgwo jaws and a large screw in the middle. it is made just for this problem. most places that sell the slack adjusters will have this tool. or a chisel and hammer and a good aim. good luck!
  6. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    lastgoodusername is right, your best bet is heat. Just keep some water near by. You'll beat yourself to death trying to pull it off without a torch.
  7. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    I bought a trailer where the slacks were stuck on so bad i had to cut them off and put all new s cams on good luck your best bet is heat and a way to pull on it at the same time while hitting it also.
  8. DL550CAT
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    thanks I was wishin for an easy trick. I'll go fire up the hot wrench and try to shield the air bag. Think I will invest in a puller. Anyone tried the Tiger puller or the OTC?
  9. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Check if the s-cam bushings are worn, or if the cam is old chances are it is worn and junk anyway. If the wheel is ready for brakes you could pull off the wheel/hub, then cut the s cam somewhere in the middle to get it all apart and do a complete brake job.
  10. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    lack Adjuster Puller from Snap-on pops them right off, in extreme cases apply heat.
  11. lastgoodusername
    444
    215
    Dec 18, 2008
    central NC
    i understood that it was the slack adjuster, just giving another good use for a hot wrench. seized bolts are another place where heat is extremely useful. johnny
