Stryker SR-497HPC
Discussion in 'CB Radio Forum' started by awright, Nov 8, 2018.
  1. awright
    awright Light Load Member
    86
    15
    Dec 20, 2016
    Is this thing worth putting the money into or are they junk?
    Way too much white noise
    Volume/Squelch on same dial, and they spin together very frustrating
    Now when I turn radio on in the mourning, I can't hear guys talk until I wiggle the channel selector. Like it is falling off frequency. I get noise if I back the squelch back, but it must be on the wrong channel.
    Any pointers? Should I just trade this in and look for something new.
    This radio has been a disappointment after my 20 years of running my old Mirage 9900.
    Maybe I should find a good surgeon to go through my Mirage and get it back to work.
  3. Timin770
    Timin770 Road Train Member
    1,657
    1,757
    May 27, 2011
    Canton, GA
    How many miles you got on it?
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,667
    1,242
    Jun 26, 2017
    I assume this is a used radio that you had for a while? Sounds like you need to pull the cover off and spray the control pots, and the channel selector pot with some detoxit spray. then work the knobs back-and-forth to work the cleaner in.
    It’s possible the volume knob might be a little too close to the squelch knob, I’ve seen that before. You could try to pull the volume knob out about a 16th of an inch, to see if that helps.
    I think cleaning the pots will solve your problems though. Let us know if that works or not.
    Timin770 Thanks this.
  5. awright
    86
    15
    Dec 20, 2016
    Thanks for the advice. I will see if I can find a radio shop that I can trust to open this thing up.
    I have not used this radio very much at all. It has spent most if its time back in the box for the last 5 or 6 years. I just use it for my spare while the Mirage is down.
  6. Ridgeline
    22,108
    113,242
    Pull your volume knob off and see if the squelch spins without it being on. If it does, it is either bent or it is gummed up with lube that is bad.
