Stripped wheel studs. Again.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wildcat74, Dec 4, 2011.
  1. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    I just replaced every single one of the studs on my drives due to several having been stripped on my truck when I bought it. Now here I am about a year later and I've got a couple more wheel studs stripped yet again. I know for a fact that the inner lugs are long enough to not be bottoming out and I know the lugs are not being over tightened. Could a slightly bent wheel be the cause of this? What else could be the cause for this? I am sick of dealing with pulling the hubs and the downtime involved in the job. Anyone got any advice?
  3. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    Use antiseize on your studs and inner nuts if you don't already. It seems to help. You don't have a bent wheel. An occasional stripped stud or a twisted off inner nut is just part of the deal with stud pilot rims. I haven't had any stud problems after getting new enough equipment to have hub pilot rims.
  4. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    When replacing the stud, try to also replace the inner and outer nut too. The threads on the inside of the inner nut may be worn. Even with the torque wrench set correctly, if the threads are full of rust and corrosion, or worn the wheel will never torque right. Since you really can't clean the inside threads it is better to just replace them before a wheel comes off!
  5. Tardis
    Tardis Light Load Member
    211
    118
    Nov 6, 2011
    banned or retired
    I'd been told that anti-seize on wheel studs was not legal.
  6. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    Quit listening to idiots.
    SL3406, mslashbar, Elvenhome21 and 3 others Thank this.
  7. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Its not recommended on hub pilot wheels cause it gunks up and prevents the washer from spinning from the nut. On the old ball and seat style its the only way to go.
  8. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    You put a drop or two of oil in the gap between the nut and washer on hub piloted hardware. The washer face against the wheel remains dry.
    I put small amount of oil on stud threads too. Dry threads require a tad higher torque.
    I always use torque wrench on wheels. Never had one loosen or become hard to remove next time.
  9. Semi Crazy
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    On subject, Wildcat do you have steel or aluminum rims? They use different length inner nuts.
    ALCOA p/n
    5988R/5988L Inner Cap Nut
    For use with standard length studs (1.31” to 1.44” stud standout) or longer studs not to exceed 1.88” stud standout.
    Full external threads, counter bore 5/16” deep at open end. For use with aluminum inner and outer wheels.
    7896R/7896L Inner Cap Nut
    Inner thread 3/4” x 16, outer thread 1-1/8” x 16. For use with steel inner dual wheel and aluminum outer dual wheel with 1.31” to 1.44” stud standout.
    EUCLID p/n
    Aluminum Inner & Outer Wheel
    Hardened inner Cap Nut
    E5988-R & L 1-1/8"-16 3/4"-16 3-1/16" Inner Cap Nut
    or
    E5978-R & L* 1-1/8"-16 3/4"-16 3-1/16"
    *E5978-R & L has a few more inner threads than E5988-R & L.
    Steel Inner Wheel & Aluminum Outer Wheel
    E7896-R & L 1-1/8"-16 3/4"-16 2-9/16"
    or
    E7897-R & L 1-1/8"-16 3/4"-16 3-1/16"
    I used the Euclid E5978-R & L when I switched from steel to aluminum inners.
    What brand hardware are you buying? Could be bad Chinese crap.
    Make sure your hub studs are minimum 1.31" long.
    I have 4 boxes of used L&R inners for steel wheels free to anyone willing to pick them up.
  10. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    I'm not sure on the brand or country of origin on the studs but I replaced the studs inner and outer lugs all in one shot the last time and used anti seize on all the above.
    I'm using steel inners and aluminum outers.
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    You never use antiseize on wheel studs. Antiseize or oil on wheel studs acts as an anti-friction lubricant. When you do that, torque values change and you will over torque and stretch the threads.
    One might think torque is torque regardless. Stick a torque bar on an impact and the lubricant aids how far it goes. They figure it can increase actual torque 10 ft lbs using an impact. Then you are dealing with metal fatigue on stretched threads.
    If you do like semi crazy and use a torque wrench, then it doesn't matter. The specs apply to dry. Wheels aren't on there long enough to rust over that bad. Antiseize is good for like exhaust manifold bolts.
    Wildcat, I would of replaced everything as a set. Sounds like the previous owner over torqued which stretched the studs and inner lug threads both, which allows just enough play for a 1 year wear out on the outer lugs.
    Both semi crazy's posts are good.
