How much is it and what does it entail to stretch a truck, put air ride, and/or all around car hauler suspension. Thanks!
Stretching and Lowering Cost
Discussion in 'Trucks [ Eighteen Wheelers ]' started by CiccarelliTruckin, Aug 23, 2016.
how much? i dunno, but in the end, no matter the perfection of the shop, i'd nary trust a cut frame.
it'd be cheaper to go and buy a truck to spec. plenty of great used ones. -
Don't know squat about hauling cars but here:
http://www.thetruckersreport.com/truckingindustryforum/threads/stretching-a-truck-frame.196788/ -
Rails to stretch the truck will cost about $50/foot per rail. Plus you'll need a sleeve to reinforce the spliced area. The insert sleeves cost about the same per foot. There are 2 ways to go about stretching. Best way IMO is to weld the rails onto the back of the truck, then slide the drive axles back and re-drill the frame. Install insert rail so that it extends about 2 feet on either side of the splice. Insert rail should have its ends cut at a 45 degree angle to help alleviate stress.
2nd way is to cut the frame in front of the drive axles and splice a section in. Then sleeve the entire area that was installed plus 2 feet past the splices (again, ends of the insert rail should be chopped to a 45 degree angle). This method should be quicker as there is much less frame drilling required. Downside is you now have 2 splices in each rail rather than 1.
Driveshafts, wiring and air lines will need to be lengthened as well. Depending on the amount you decide to stretch, a 3rd drive shaft and 2nd carrier bearing may need to be installed as well.NoBigHurry, Klleetrucking, CiccarelliTruckin and 2 others Thank this. -
how much more per mile does it pay
alds and Toomanybikes Thank this. -
Airride for your steer axle will cost you about $2500 and on top of that a flip bumper but it rides a lot better. Id go with AirridebyHorse known for quality craftmenship
CiccarelliTruckin Thanks this. -
BoxCarKidd Thanks this.
i dont know how to post pictures here but i have a render how our truck will look with airride.
