Stretched 379 Too Long For Reefer/Van?
Discussion in 'Ask An Owner Operator' started by GCast, Apr 26, 2017.
  1. GCast
    GCast Bobtail Member
    14
    16
    Apr 25, 2017
    Some of these spots guys have to back into are pretty tight for a cascadia. What do these guys in their 300- 400 in wheelbase petes do if a spot is too tight? Or is van/reefer just not recommended with those types of wheelbases?
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    I will not say I've never seen a large truck pull a refer trailer but the one I have were hauling specialized freight. I E Not food. So not going to food where houses. I pull a specialized refer trailer hauling special commodities usually medical equipment, art work or tools for a semi conductor company that needs to be climate controlled. A lot of our drivers do have long wheel base trucks usually no longer then 315". The places we go to are not usually tight. I can't imagine a large car doing produce. They could not handle the weight.
  4. Gunner75
    Gunner75 Road Train Member
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
    Well I would imagine those guys would know where they are going and don't worry much about it
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    There is a small outfit in Wa here that runs a couple long pete's and Kw's and I think 53'ers to Ca running produce so they are out there.
  6. LumbraX
    LumbraX Medium Load Member
    394
    443
    Sep 12, 2015
    Orlando, FL
    Most of them will tell you it's easier because the trailer is turning much slower.
    Big_D409 Thanks this.
  7. Ridgeline
    22,103
    113,210
    Got a clown that drives on US23 and I see him every other day, he has such a huge gap between his sleeper and the reefer I wonder if there should be a regulation limiting it. I could put my Prius right between the truck and trailer and maybe have a couple feet to spare.
  8. passingthru69
    How does that make him a clown
    His fuel bill. He is the one who has to back it up and turn the turns..
    So unless he runs you off the road, why worry. You drive a Pirus and admit it..lol
  9. jeastonjr
    jeastonjr Light Load Member
    99
    120
    Nov 4, 2013
    Weymouth,Ma.
  10. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    The guys that run those long wheelbase trucks generally know the customers they will easily fit at. Starting out in a truck like that you would have a heck of a time.
    Anyone know the weight difference of 2 identical trucks and how much each extra foot of wheelbase adds to tare weight? Curious..
    Oxbow Thanks this.
  11. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Just frame rail and electrical and airlines.. so probably in the neighborhood of 50 lbs a ft. Stretch it far enough and you fit to add an extra crossmember and carrier bearing so that adds a bit more.
    Oxbow and gokiddogo Thank this.
