Straps for oversized loads
Discussion in 'Flatbed Trucking Forum' started by Simplespeed, Nov 29, 2020.
  1. Simplespeed
    Simplespeed Light Load Member
    103
    88
    Jun 12, 2013
    New to step deck oversized loads. Are you guys using extra long straps or straps with a hook that you can chain to?
    And tips or advice are appreciated, thanks.
  3. bonder45
    bonder45 Road Train Member
    1,803
    5,445
    Oct 2, 2011
    Williston, ND
    It honestly comes down to the load each time.
    Trust yourself and if you think you should add 1 more strap, just add it. ( or chain )
    Simplespeed Thanks this.
  4. Simplespeed
    103
    88
    Jun 12, 2013
    What i meant was are you guys using 40' - 60' straps or just any strap with a chain hook on the end so you can chain to it to get the extra length?
  5. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    40’ long straps usually do the job,u can use straps with chain ends and hook’em together but you will need winches on both sides or ratchet straps.
    Another trick is to use chains on one end and attach the hook to it to get the extra length needed.
    I also attach two straps by the hook like a handshake,it all depends on the load
  6. IH Truck Guy
    4,119
    46,696
    Mar 2, 2008
    Purgatory
    Then wrap the 2 ends together with duct tape so if the straps loosen up they wont slide apart.
  7. blairandgretchen
    13,231
    70,451
    Dec 9, 2011
    South west Missouri
    I bought a dozen 40’ straps that I occasionally use for wider, taller stuff.
  8. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    I just use ducktape to tie down everything you always have plenty of length, just be careful on the corners.
  9. kylefitzy
    kylefitzy Road Train Member
    4,597
    18,983
    Aug 12, 2007
    Kansas city,Mo
    Shippers Supplies will make you any length strap in what ever color you want with what ever hook configuration you desire.
    I carry 5 50' long straps and do my damnedest to not have to use them. They suck to roll up by hand and it seems like the trailers I use them on never have rub rails for my strap winder. I tend to only use them on crates.
    When your loads get big enough indirect securement is not the best method in my opinion. I frequently secure 16'-20' wide loads with 5' long straps and 8' long chains.
  10. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    You can also loop the end of your chain and use the flat hook from strap.
    kylefitzy and cke Thank this.
