Strange DD15 engine sound
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Drivesemi2, Mar 18, 2018.
  1. Drivesemi2
    Drivesemi2 Bobtail Member
    2011 Freightliner Cascadia DD15 engine makes a noise when accelerating just a little above idling RPM and it gets a little louder. Once acceleration pedal released it needs about 3-7 seconds for sound to go away and then engine ideals nice and quiet. It looks like sound is coming from airbox at the top of the engine through a breather. Best way to describe it is it almost sounds like a motorcycle in the distance. Kind a low frequency knocking sound, like some of the hoses were not connected, but we checked all hoses are connected.mechanic adjusted engine brake valve, he thought that valve was slightly closed and that was making sounds. After adjustments, sound is still there, No dash lights come on and truck is still running great just making the noise. Any suggestions? Before I ta
  3. Drivesemi2
  4. fatmike02
    fatmike02 Light Load Member
    127
    159
    Mar 1, 2018
    Sounds like my cummins ram pickup if I have the exhaust brake engaged at idle. Sound exact sound that comes from the air intake.Just saying but anyway your truck obviously has jakes.
  5. Yayaya
    Yayaya Bobtail Member
    22
    15
    Oct 5, 2018
    Check all your valves for adjustment not just Jake's.
  6. Yayaya
    22
    15
    Oct 5, 2018
    Just saw the video and I'm 95 percent sure you have an intake valve stuck open. Remove the inspection plate on the bottom of the bell housing and turn the engine over to tdc compression stroke on either 1 or 6 (red dot on the flywheel) check valve lash on intake and exhaust valves. Turn over engine again until you see the red dot on the flywheel and check the other intake and exhaust valve lashes..
  7. Kurt418
    Kurt418 Bobtail Member
    I have 2015 cascadia. A strange whistle noise from my engine. What could that be?
  8. Yayaya
    22
    15
    Oct 5, 2018
    Hard to say. Turbo issue? When is the last time u checked the air filter. Only on acceleration??
  9. DJLV
    DJLV Bobtail Member
    @Drivesemi2 . Did you fix the problem w loud sound on your truck? I have the same issues but don't know what is the problem on my dd13 engine. If you did resolve the problem would you please tell me how did you do it . Thanks
  10. Keepontrucking2016
    Keepontrucking2016 Light Load Member
    170
    40
    Apr 7, 2016
    I have the same issue did u figure out the problem I replace engine air filter new oil change and filters new turbo does not eat oil no leaks anywhere only does it on acceleration or on a cold start in the morning
  11. 377pete
    377pete Light Load Member
    147
    14
    Oct 26, 2009
    dfw
    Anyone figure out what was causing the noise
