STRANGE CASCADIA TURN SIGNAL ISSUE
Discussion in 'Freightliner Forum' started by gtilogistics, Jun 13, 2020.
  1. gtilogistics
    gtilogistics Bobtail Member
    40
    7
    Sep 16, 2012
    Hey Everyone, I am having an issue with my turn signals. When i turn the left or right signal on, the light flashes fast. If i turn the emergency lights on, the emergency lights flash like normal and not fast. The problem is the lights on the back of the tractor dont flash. I checked the bulbs because if you turn the lights on of the truck, those will come on. There is an issue with them flashing. The lights on, those back two red lights are on (these lights are the ones under the reverse light). When i turn the emergency lights on, they dont flash but the rest of the truck flashes normally on the sides and front inside headlights, when i turn the turn signals on they flash fast but still not on the back. I checked all the sam relays on driver side when you pop the hood open but they seem fine. Are there any other relays or fuse located anywhere else? I checked behind the glove box but didnt see anything related to the lighting
  3. mitrucker
    mitrucker Road Train Member
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    Have you tried replacing those tail lights???? Usually turn signal flash fast when there’s a bulb out. It very well could work the same with LED’s.
    O.Henry Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Yes burnt out lights or broken wire. The faster flashing is telling you that there is a light not working in the circuit.
    O.Henry and Motto Thank this.
  5. Runtransporting
    Runtransporting Bobtail Member
    What did u find wrong I have same issue
  6. Oleg D
    Oleg D Bobtail Member
    16
    10
    Jun 29, 2021
    Canada
    Did you find out what it was? I've the same thing now
    KDHCryo Thanks this.
  7. Oleg D
    16
    10
    Jun 29, 2021
    Canada
    In my case it eas broken wire
    Iamoverit and KDHCryo Thank this.
