Straight Truck Axle and Gross Weight Confusion
Discussion in 'Ask An Owner Operator' started by MercySakesAlive, Nov 5, 2021.
  1. MercySakesAlive
    MercySakesAlive Light Load Member
    104
    45
    Aug 8, 2008
    seattle ,wa
    I'm driving a 3 axle straight truck for a job. I'm confused as to what i can legally weigh on my axles. There's a sticker on the driver door that says:
    GVWR: 50,000 lbs
    Front axle GAWR :12,000 lbs
    2nd axle (drive): 19,000 lbs
    3rd axle (drive): 19,000 lbs
    Can i legally weigh 12,000 on the front and 38,000 on the drives combined or am i asking for trouble at the scale? I have a permit from the state I'm traveling in for 50,000 lbs so maybe THAT fact makes me legal?
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    How much weight do you have truck registered for?
    THat sticker on the door tells you the weights ratings on those axles.
    So im gonna say, no your truck wasnt set up right to haul 50 thousand pounds and be completely maxed on on your axles from factory.
    you should be running 20k steer and 44k rears. Sounds like an illegal death trap the way you want to max it out
  4. MercySakesAlive
    104
    45
    Aug 8, 2008
    seattle ,wa
    So the GVWR rating on the door sticker... that tells me what the vehicle can handle but not what I'm legally allowed to carry?
    Bean Jr. Thanks this.
  5. Don379
    714
    1,286
    Jan 7, 2021
    correct sir
    Bean Jr. and Studebaker Hawk Thank this.
  6. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    The sticker on the door tells you the gross vehicle weight rating.
    That means that the weight of the truck as it sits Plus the load that you carry on the truck can't be more than fifty thousand pounds.
    So let's just say that your truck weighs 20000 pounds. Then the amount of weight that you can actually carry on that truck is 30,000 lb.
    Now your axle ratings tell you how that weight is distributed on your truck. So you're legally allowed to have twelve thousand pounds on the front axle and thirty-eight thousand pounds on the rear axles.
    It's possible that you could pull onto a scale and your weight is 50000 pounds or less but you could be overloaded on one of your axles if your truck wasn't loaded correctly. So for example if whatever you're hauling was loaded too far forward in the front of the truck you may have more than twelve thousand pounds on the front axle. You can't be over the weight of what your individual axles are. And you cannot be over the gross weight rating of the truck.
  7. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    You need to find the weights and measures charts for the state or states you travel in. The break out the tape measure.
    Also remember you can not exceed what the tires, or the axle of the legal limits are
  8. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Ok here's the real answer. There are three weights that matter. It's the less of the three.
    1. GVWR of the axle.
    2. Weight rating of the tire.
    3. State rating for the road.
    The registered weight means nothing, unless you go over it...
    gentleroger, Bean Jr. and lester Thank this.
  9. Ridgeline
    22,112
    113,286
    Yes you can WEIGH 12,000 on the front and 38,000 on the drives and no you are not asking for trouble at the scales.
    permits are all about taxes when it is below 52,000lbs gvw.
    if you are permitted to do 80,000, your axles and truck has to be setup for it.
  10. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    In lots of States 34,000 is the max weigh on a tandem. So at 38k you’ll be over axle.
    Accidental Trucker Thanks this.
  11. abyliks
    abyliks Road Train Member
    3,747
    8,695
    May 2, 2010
    ludlow MA
    This is really going to depend on the state, Mass is 73,000 on a straight 10 wheeler if you are specd for it, try that down in CT and you’ll get silver bracelets
