straight pipes and inserts
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oscar the KW, Oct 31, 2012.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    Has anyone ever had straight pipes and later on put the inserts in them? Was wondering if there were any changes to your fuel mileage by doing this. Or any changes in performance. I am thinking about pulling the stock pipes off my W900 and putting on some 6" Lincoln Exhaust with inserts in them to get rid of the rumble, truck is straight piped now.
  3. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    If your going to go with straights, go 8" with the baffles in them already. 6" are old school. Make sure when you order them that you tell them you want baffles in them.
  4. Oscar the KW
    12,246
    28,114
    May 19, 2011
    I am gonna be old school then, because anything bigger than 6" pipes on an aerocab looks way to big for my liking. Besides, the price of 8" pipes are rediculous.
  5. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    7" go good on a aero cab. But the inserts you talk about only go in 7's and 8's if im not mistaken, I could be wrong.
  6. Buckshot7cz
    Buckshot7cz Light Load Member
    168
    26
    Oct 16, 2012
    Sandy Oregon
    dynaflex makes a 6" center spool called a "Quiet pipe" should do the trick... your local chrome shop should be able to hook you up
  7. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I just put inserts in my 5" straights. They make them for every size. Did not quiet the truck down much but took some of the bite out of the sound. Performance is the same and I couldn't tell you on the milage. They really do not restrict the air flow at all.
  8. GP1500SC
    GP1500SC Light Load Member
    91
    32
    Sep 10, 2011
    mo
    7 inch quiet inserts are 5 inch straight through
    6 inch quiet inserts are 4 inch straight through
    I like my 7 inch pipes with the quite inserts, you can still talk to your passenger with out shouting.
    but put her on a hill you still here her talk.
    The jakes are alittle on the noisy side
