Sterling L7500 low air alarm buzzer location.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BryRylanKW, Apr 7, 2016.
  1. BryRylanKW
    BryRylanKW Light Load Member
    118
    17
    Feb 1, 2011
    cape cod MA
    Hello everyone looking to see if anyone knows the location of the low air alarm buzzer on my 2002 sterling L7500 the light on the dash comes on when the air is low but no buzzer, I'm taking one of my guys for his license next week and would like the alarm to work. thanks.
  3. Animosus
    Animosus Heavy Load Member
    709
    2,781
    Dec 7, 2015
    SE Wyoming
    Last six of the vin and I'll see if I can find some location diagrams.
    BryRylanKW Thanks this.
  4. Animosus
    709
    2,781
    Dec 7, 2015
    SE Wyoming
  5. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    It's very common for the wires to break on those. The buzzer itself is just snapped in, they come loose the wires break. You can usually solder them back on it and it works fine. Whether you fix it or replace it, take some hot glue and dab around the 3 mounting tabs of the buzzer to make it last a lot longer. The plastic cover is easy to get apart and most of the time it's just a broken wire.
  7. BryRylanKW
    118
    17
    Feb 1, 2011
    cape cod MA
    I think the cluster has a broken copper on the board behind it, I installed a new buzzer and it still didn't work so I just found which wire feeds the cluster for the low air light and tapped into that with a new buzzer from radio shack.
