`05 Sterling day cab:
Is it normal for the suspension to make crunching sound (sounded like ball joints were about to give out) when front end dips into a pothole &/or making a turn at slow speeds (10 mph & lower)?
Also, is it normal to have to apply a lot of pressure to the brake pedal to slow it down? I had to put a tremendous amount of pressure on the brake pedal to stop, when loaded heavy traveling on a downgrade to come to a complete stop # an intersection.
Sterling Day Cab Suspension & Brakes
Discussion in 'Questions From New Drivers' started by RightSideSlide, Jan 14, 2011.
Sounds about right for a Sterling. Better watch your pre-trips and take it slow cuase those things are biggest hunks of junk on the highways.
If DOT/NTSB had any sense they would outlaw those POS trucks right now!
Keep the seal-belt clip handy cause you might be needing to jumping out of that rolling piece of garbage, when it really goes south on you.RightSideSlide Thanks this. -
as for the pressure on the brake pedal, my first thought was the trailer brakes were not working......or not adjusted properly.. or maybe due to the cold temps, maybe some ice is inside the drums...??
do the brakes do this all the time...??? do you have more than one trailer you pull..??RightSideSlide Thanks this. -
How many miles on the truck? Might be time to replace worn out supension components. If it is a walking beam suspension on the rear it may be your bones you hear cracking.
I drive one everyday and mine started doing exactly what you described so I took it in to the mechanic. He said the one I am driving was missing the rubber boot on the brake pedal linkage he sprayed some lube on the linkage and it was much better. I mentioned the springs and he checked it out, said they were dry and told me to put it on my pretrip so they could schedule it to be greased and so they could replace the rubber boot. He also said the Sterling's were prone to this problem.
Been doing physical therapy (workmen's comp). Worked out very well, but my better guess is, if another company hires me on, when they put me on their insurance policy, everything that happened will magically appear for them to review, (compliments of insurance under-writers based on the employer's "locked door & adjust report")
The company I was driving for came & picked up the truck & trailer, while I got an ambulance ride. After the hospital gig, my kid & her b/f came to get me, then we went to the yard to p/u my car. Much to our disappointment, we didn't get to see the wrecked truck as it was locked up in the shop garage. Gee, I wonder why.
Medical release date is 1/24/11. I tend to think that finding another job will be (at best) very challenging, as I won't jump back on w/ a bad company running junk just to be in the game. Between the hard lesson learned & CSA 2010, might be best off doing something else for a while until things subside a bit (1-3 years?).
Over 25 years since last moving violation, clean criminal record, zero points on CDL. Only 2 very mild scuffs on DAC from 1st few months of driving big rig. Oh well, again, "no one else got hurt", & this msg being sent from a home PC, not a prison PC. <~~~ "The biggest bonus one can hope for when a big rig accident occurs". -
(1) Pulled single 6000 gal tankers & single 48' ft walking floor trash trailers. No double or triples.
(2) It's a small company, so I pulled all their walking floor type trailers repeatedly. Never had braking issues when pulling these trailers w/ freightliner. Only w/ the Sterling. -
How do the front end and brake parts look during your pre-trip? Take a close look at the pins and bushings to find any excess wear... crawl under the truck and measure the brake stroke... that will tell you if the brakes need adjusting...
