Sterling dash project
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Big_D409, Dec 14, 2016.
  1. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    Well seeing as how I'm married to my old Sterling, I figured I'd finally replace that worn out, plastic, crumbling dash. This was hands down the best thing I could have done. The new one is all fiberglass and will probably out last the truck... Unless I never come to my senses, lol
    Took me a week to complete, which really put together was 3 days of work. Taking the old one our was easy, as most of the mounts were broken and the dash itself bad numerous cracks. It was to the point of hitting a bump and watching the dash bounce...
    Aside from reusing the instrument cluster, all the other gauges and switches came out of a peterbilt. The old rocker switches just weren't doing it for me. Eventually I'll swap the instrument cluster with the new one I made, but for now I wanted to make sure theverything original gauges still worked. Moving wires around that have been in the same place for years had me leary on installing new gauges. Since everything still works, I'll eventually add in the new panel.
    Now time for pictures!
    FB_IMG_1481754970782.jpg FB_IMG_1481755064126.jpg FB_IMG_1481754990816.jpg FB_IMG_1481754996324.jpg FB_IMG_1481755043288.jpg
  3. Big_D409
    552
    729
    Dec 1, 2012
    Just a point of reference ,as many of my friends didn't understand why I'd do such a thing. FB_IMG_1481755047326.jpg
    Oxbow and Freightshaker613 Thank this.
  4. Big_D409
    552
    729
    Dec 1, 2012
    Cleaned up the mess of wires and air lInes the factory left behind. A one size fits all isn't in my game plan and harnesses that I did not need went away.
    Along with the stereo harness. That big bulky thing made fitting the new dash easier. Since I'll be moving the stereo up to the overhead console and running new speakers and wires, why not eliminate the old stuff. FB_IMG_1481755013100.jpg FB_IMG_1481755034659.jpg FB_IMG_1481754975754.jpg
  5. Big_D409
    552
    729
    Dec 1, 2012
    FB_IMG_1481755068492.jpg FB_IMG_1481755072524.jpg FB_IMG_1481406828478.jpg FB_IMG_1481755104093.jpg Now the finished product! Along with the rosewood, I got the dash to match the exterior paint. Had it smoothed to eliminate that textured look and went with an eggshell finish. After sitting in my friends extended hood, dealing with a super flashy reflection was not in my game plan.
    The only party foul... I forgot to send my ignition panel to the paint booth. No big deal as I'll try to get one in rosewood.
    The paint was PPG if I remember right. A friend did it for me. I trusted him over me since he deals with top dollar show cars.
  6. Big_D409
    552
    729
    Dec 1, 2012
    All in I had 1600 for the dash, another 300 between switches and gauges, a week of down time (which I didn't mind the least), and a lot of fun doing this.
    Never even took the seats out or the dog house. Dash went in and out through the passenger side and I lucked out with having to do little fabrication to make the new dash fit.
    If only it was done like this from the factory...
    I know when I was on my glider kick, I wanted to go this route, but glad I never pulled the trigger on that.
  7. Pnwtrucker
    Pnwtrucker Medium Load Member
    383
    821
    Nov 5, 2016
    Excellent work! That's a sharp looking dash.
    Oxbow and Big_D409 Thank this.
  8. Big_D409
    552
    729
    Dec 1, 2012
    Thank you! Very much appreciated!
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Looks good. That brings back some memories of when I worked at Con-way. I lost count on how many of those I changed, but it was enough to where I got it down to about 6 hours. I job I do not miss doing at all. They would crack so bad that gauges, switches, the MV3 valves and even fuse panels fell out. The worst part about that job was that I was replacing it with the same POS that I knew would crack again.
  10. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    I never seen the inside of a sterling before, but you did a great job. Must be nice to run around in a tank top and shorts it's supposed to be 4 degrees later tonight in Ohio.
    snowman_w900 and Big_D409 Thank this.
  11. Big_D409
    552
    729
    Dec 1, 2012
    LOL that was my father, took it our for a quick team run. I dealt with Detroit and Chicago today and yesterday... too cold lol.
    This truck looks completely different from when my father had it. Definitely not your typical sterling on the inside.
