Stereo Harness for Kenworth???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Displaced Yooper, Feb 20, 2011.
  1. Displaced Yooper
    Displaced Yooper Light Load Member
    152
    49
    Oct 18, 2010
    Detroit, MI
    Does anyone know what type of harness Kenworth uses? I'm pretty sure they use the same harness connectors as one of the major automakers, but I'm not sure which.
    I'm going to be getting a new stereo for the truck very soon, as the current one is driving me crazy. I'm hoping someone here can save me a few bucks & let me know what harness adapter to order with the new stereo.
    Thanks
  3. Poor boy
    Poor boy Bobtail Member
    49
    43
    Feb 10, 2011
    Kansas
    Just cut the harness off your old stereo. All the wires are color coded. Use butt connectors and reused the same harness for free.
    Displaced Yooper Thanks this.
  4. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Like Poor Boy said just cut it off. Companies like Metra or American International don't make a harness for KW. You could probably order it from a KW dealer but it's totally not worth it. If you want to leave the harness in the truck just cut the old one off the radio and wire it to the new one and plug it in.
  5. Displaced Yooper
    152
    49
    Oct 18, 2010
    Detroit, MI
    If I'm not mistaken, that won't work, because the harness plugs directly into the back of the OEM radio. I really don't want to hack up the original harness, because when it comes time to sell the truck, you can be #### sure the OEM radio will be right back in there.
    Like I stated earlier, I know the plugs are the same ones used by a major automaker. Just can't remember which one.
  6. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    Well unless your KW is different than any of ours it's not like any used by any automaker I've seen and I've done car stereos for 15yrs helping a friend at his stereo shop. The radio probably has a harness but if you trace it down farther you'll see there's another harness to the truck.
    You can search if you wish, I've got both catalogs laying here and neither have what any of our KW's have.
    http://www.metraonline.com/
    http://www.aius.net/
    Last 3 KW's I've ordered I ordered them without radios/speakers because all the OEM stuff is junk and WAY overpriced. However I always get them wired and it doesn't matter, with or without a radio they all have had the same 2 plugs.
  7. Pappa Bear
    Pappa Bear Light Load Member
    105
    22
    Dec 20, 2010
    Springfield, OH
    I purchased a Blaupunkt radio from Crutchfield and was going to cut and splice wires. But to my surprise the factory wire harness plugged right in to the new unit. My mechanic only had to swap two wires around in the clip. He had a special tool that releases the wires out of the clip so he could change their position.
  8. BryRylanKW
    BryRylanKW Light Load Member
    118
    17
    Feb 1, 2011
    cape cod MA
    I just looked at the color code on the back of my stock radio and matched that to the new color code of the new radio and used butt connectors everything worked for me.
  9. jfred29687
    jfred29687 Bobtail Member
    4
    Feb 21, 2011
    i have been reading on this forum for 2 yrs now i had to sign up cause i finally got an answer and u wonnt belive me but it the same on a freightliner and a kw its a vw not sure witch one but if bring your old radio in and tell them its for a vw they can narrow it down the rest of the way its a direct plug in u dont need to cut anything
  10. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    What's funny is it takes longer to dial the phone looking for a harness, then it would be to just butt connect or even solider and heat shrink.
