Stepdeck with holes and DOT inspection
Discussion in 'Flatbed Trucking Forum' started by peak, Dec 9, 2012.
  1. peak
    peak Bobtail Member
    36
    11
    Nov 5, 2012
    Hi All,
    I have a stepdeck, and due to my line of work, a few holes and splits have appeared. Nothing major, but where the holes were made, the wood split up in about 1 foot sections. The structural integrity of the deck as a whole is still fine and I dont need to replace my whole deck. I just need to know if I would pass a level 1 DOT inspection with these holes/cracks, or if I will get an out of service notice because of it. Even if I have a load on top, you can still see where the split is underneath the trailer.
    Thanks
  3. CAXPT
    CAXPT Road Train Member
    2,942
    12,641
    Feb 10, 2008
    The holes can allow a spillage of cargo, so the load isn't secure. You need to get the holes repaired. Now they may not gig you for it, but beware it is a securement issue maybe someone else can post the exact language in the Regs... I have to get to sleep.
    Good Luck
    peak Thanks this.
  4. haulhand
    haulhand Road Train Member
    How could they even say anything at all about it. Trailer decking is not in the regs at all. If I'm wrong you really need to post a link.
    OP I've been in a level one in LA of all places and had a flatbed next to me with a load of steel loaded directly on the cross members as in he had no deck at all. He was out of there before me with nothing said about it. I run a RGN now with no deck in the center between the beams so I really wouldn't worry about your small holes just get them fixed when you can.
    peak Thanks this.
  5. passingthru69
    I'm with haulhand. When I was running my 13 axle I took all the deck out of my trl. Trying to lighten my mty. weight.
    I had some loose boards on the crossmembers.
    Was through a lot of insps. Nobody said a word. Main they will hammer you on is if the boards are loose and no ld. on them,make sure you have a chain or strap holding them down.
    They can pop you for unsecured ld. Yes loose deck boards
    peak and haulhand Thank this.
  6. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    I've dealt with this issue many times when performing DOT inspections. The ruling is; As long as the existing decking is secure and the type of freight you haul cannot possibly exit through the holes in the deck, the holes should not be considered. If the decking is broken up and susceptible to possibly fall off into the roadway, then that portion would need to be removed.
  7. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    I have several missing boards on my flat, no DOT has ever mentioned it.As quick as I fix one, another breaks.
  8. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    DOT hasn't said anything to me yet.
  9. CAXPT
    2,942
    12,641
    Feb 10, 2008
    Here you go.
    -- emphasis added.
    I ran into this as an operator of a salting/plow truck, and is the only exception allowed; a salt load that is being actively used. It can be loaded where if you make corners, it spills. It is alright as that is the purpose of the load.... other than that, spillage is not allowed. If a deck has holes that a load (even on a flatbed) can fall through and become loose on the roadway, it is not, by definition, secured. Therefore, the holes in the deck CAN be a violation.
    And in the interpretation part.......
    As for RGN's etc, any equipment that you put in there, heavy or not, if it comes out it can be a violation so unsecured material in them (I've seen them, things loose inside) it can be considered unsecured items on a trailer.
    Now as we constantly talk about, you may not get gigged by someone that doesn't consider it something they concern themselves with...HOWEVER, it is in black and white, and can be
    "reasoned" that it violates the regs and thereby be a ticketable offense.
    It's a gamble, but when you win, don't say I didn't warn you. :D
  10. troop381
    troop381 Bobtail Member
    6
    13
    Dec 22, 2012
    if they dont get you under 393.100 then they can get you on 392.8 or 396.a3
  11. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Logging trailers have no decking, so I don't see where a few holes in a FB would be an issue.
