Step deck tarp transition?
Discussion in 'Flatbed Trucking Forum' started by Simplespeed, Nov 18, 2020.
  1. Simplespeed
    Simplespeed Light Load Member
    103
    88
    Jun 12, 2013
    Im new to step deck as well as tarping. I absolutely suck at tarping, but I dont mind doing the work. Tha main problem I have had is keeping the wind out of the tarps. I have two 8'x20' tarps with a flap on one end of each. Im picking up a load of crated hot tubs tomorrow and not sure how to transition from the top deck to the bottom deck. Im told the load is 8ft tall so im assuming 8ft on top deck as well as 8ft on bottom deck. And advice is greatly appreciated.
  3. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    This is the way I do it... When you are laying out the tarp over the front you want to position a d-ring right at the bottom corner of the "step" in the load so you can keep the tarp flat against the back of the load on the top deck. you will probably need to pull the tarp forward more and then deal with excess tarp in the front to get a d-ring in that position.
    Get the d-ring in that bottom corner pulling down or slightly forward and then go to the front and tighten it down. Then go to back of the top step and start tightening down towards the front, keeping the excess tarp from the transition hanging out. How do I explain it... Try to tighten down the tarp on the top deck straight down so it is parallel with the deck until the tarp starts to make a gap above the deck as you work your way to the front. keep the excess tarp that doesn't want to be pulled straight down out so you can fold/roll it onto a "flap" and then pull the flap towards the back, over what you just did. Just far enough so the flap of extra tarp that you fold over won't leave a gap between the tarp and deck or you will end up making a big tarp balloon. :D
    Sometimes you can put the excess tarp on the inside if there is enough room between the load and the edge of the trailer, but not likely with hot tubs. And they don't want you climbing on top of the load for sure. It's easy to put your foot through one of them if you step in the wrong place. They will probably have a tarping station to use. I would probably lay the front tarp forward a few feet more than usual because excess tarp on the front is easier to deal with than pulling the whole tarp forward after it's put down. it will be easier to pull it backwards if you wanted or needed to.
  4. Simplespeed
    103
    88
    Jun 12, 2013
    Thank you. I think I understand what you are explaining. It definitely gives me something to work with. They said the whole load is 47ft and i have 2 20' tarps so i guess we'll see what they say. They are also 8ft drops and the load will probably 8ft tall on top and bottom deck. Gonna be interesting.
    Between moving from a company driver to buying my first truck and starting flatbed for the first time ever, tarping has been the hardest part for me by far lol.
    cke Thanks this.
  5. HillbillyDeluxeTruck
    5,889
    30,041
    Mar 3, 2013
    San Antone
    You wont have 8ft stacked up on the upper deck. Do you have a 48 or 53ft stepdeck?
    What "I" would do is have a tarp specifically for the upper deck. Probably a 6ft drop x whatever your upper deck length is, maybe 2ft longer.
    Simplespeed Thanks this.
  6. beastr123
    beastr123 Road Train Member
    2,803
    22,847
    Jan 2, 2014
    Moose Jaw SK CAN
    A 1inch strap or 2 passed from a ring on one side to the other around the transition will help with the tarp ballooning if you can trap the excess tarp between the strap and transition side
  7. Simplespeed
    103
    88
    Jun 12, 2013
    It aint pretty bit its working. I'll snap a pic tomorrow. Thanks guys.
    D.Tibbitt and cke Thank this.
  8. Simplespeed
    103
    88
    Jun 12, 2013
    Good idea. I also need some 6' tarps. This 8' is a huge pain on smaller stuff. Im renting a 51' step. It's 41' bottom and 10' top but plan on buying a 53ft step next year.
  9. beastr123
    2,803
    22,847
    Jan 2, 2014
    Moose Jaw SK CAN
    Pick up a 18X20 steel tarp with rings at 2ft and 4ft (and maybe at 6ft) up on all sides. You will find it the most useful tarp you own.
    It gives you a 6ft drop that will cover 8 ft deck to deck and will also cover your top deck down to the deck in front with a 2ft overlap over a load on the bottom.
    Simplespeed, cke and D.Tibbitt Thank this.
  10. sbaumann14
    sbaumann14 Road Train Member
    1,215
    1,389
    Sep 1, 2010
    Rhinelander, WI
    I have the same 51. I use 3 24x24, 2 of them have an 8 foot flap on the end. Covers an 8 foot tall load perfectly (8×8×8=24) and the flap on each end covers that
  11. cgilliland
    cgilliland Medium Load Member
    321
    743
    Mar 13, 2017
    i dont understand what 18x20 and 24x24 means
    cke Thanks this.
