Steering wheel removal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by oneroad, May 25, 2020.
  1. oneroad
    oneroad Light Load Member
    90
    30
    Apr 3, 2015
    WILLIAMSBURG,ky
    Hey. I just got a 2019 cascadia. The steering wheel is off to the left. Was wondering how to take it off and turn it a little. Took horn button cover off and there's a Allen bolt instead of a nut.
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Would it be easier to clock the shaft on the steering gear instead?
    Dino soar and Rideandrepair Thank this.
  4. Rideandrepair
    17,202
    55,799
    Aug 8, 2015
    I doubt it will work, when I replaced my steering box, I tried that, 1 tooth makes a big difference. I’ve never taken a steering wheel off, but I’m sure it’s easy enough. Might need a puller.
  5. AModelCat
    154,243
    Is the drag link adjustable? I'd start there if it is.
    Snailexpress and Rideandrepair Thank this.
  6. Rideandrepair
    17,202
    55,799
    Aug 8, 2015
    My WS had one. I’d sure like to put one on my Freightliner. I wonder if they’re available? Nice option to have.
  7. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    It should be adj. when louse the 2 pinch nuts then turn it, till steering wheel is where you like it?
  8. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Position the truck’s front wheels where it would be if it was traveling straight on the road, disregard the position of the steering wheel inside the cab.
    Have someone mark the position of the steering shaft and gearbox with a grease pencil
    Have someone loosen the pinch bolt and using a pry bar, take the steering wheel shaft off the steering gear box and move it a few notches in the direction it needs to be while you are inside to help determine where the steering wheel should be centered.
    Reinstall the shaft and tighten the pinch bolt, take it for a drive to confirm the wheel is centered where you want it.
    If it isn’t, repeat the above procedure until you’re satisfied.
    lester Thanks this.
  9. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Most steering shafts are blind from the shaft to the gear. Atleast TRW and Shephard both are.
    I always remove the steering wheel to straghten. Steering wheels are always infinite and the same spline.
    OP....I would check with the OEM on the removal. I am not familiar with Late model FL
  10. oneroad
    90
    30
    Apr 3, 2015
    WILLIAMSBURG,ky
    Thanks everyone.
  11. oneroad
    90
    30
    Apr 3, 2015
    WILLIAMSBURG,ky
    What do u mean by clock the gear on the shaft?
