steering shaft/u joint play
Discussion in 'Canadian Truckers Forum' started by Xyrex, Apr 9, 2023.
  1. Xyrex
    Xyrex Bobtail Member
    15
    6
    Nov 27, 2020
    Hello I'm looking to find out how much steering shaft/u joint play is acceptable and what warrants replacement. Also is it only up and down play or side to side how about the shaft part that goes into the column?
    Thanks
  3. Flint1
    Flint1 Road Train Member
    1,137
    9,748
    Sep 4, 2019
    Alberta
    Here's a screenshot from the Alberta CVIP manual.
    Looks like 1mm rotational between splines and 6mm side to side/up down.
    Another Canadian driver and Xyrex Thank this.
  4. Xyrex
    15
    6
    Nov 27, 2020
    How can I measure 6mm? Other than eyeballing it
  5. Flint1
    1,137
    9,748
    Sep 4, 2019
    Alberta
    Dial indicator with a magnetic mount.
    6mm is pretty close to 1/4"...
    If it's too close to call change it..
  6. Xyrex
    15
    6
    Nov 27, 2020
    Thanks
  7. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    While your checking steering wheel shaft. Check the pitman arm nut is tight on the steering sector.
    There should be no play on that nut.
