Steering gear box???
Discussion in 'Experienced Truckers' Advice' started by RepoweredRookie, May 12, 2024.
  1. RepoweredRookie
    RepoweredRookie Light Load Member
    137
    122
    Apr 16, 2019
    Hey guys, 1999 Freightliner Century S60 12.7
    Had a clunking noise in steering wheel couple months ago (clunked 3-4 times). I changed power steering filter and fluid 10w-40).
    Now power steering gets stiff occasionally. If truck sits overnight, it seems normal. So I was running normal today, hit a bump in the road, and then went stiff like no PS. Do you guys think the gear box or PS pump is better to change first?
    Thanks for any advice.
  3. RepoweredRookie
    137
    122
    Apr 16, 2019
    I do want to add, there is no wandering in the lane, no bad tire wear, no lag from turning steering wheel to tire movement.
    There is a small leak, a clunk rarely, and most common is stiff steering wheel - like to PS pump is not working.
  4. AModelCat
    154,240
    Diagnose it before throwing parts at it. Its cheaper.
    If I were to randomly throw parts at it I would not start with the pump. Hydraulic pumps won't start and stop pumping at random unless there's a built in relief that's sticking.
    I would start down at the box. A good shop will have a flowmeter they will plumb in and load up the system to see what's working and what isn't.
    Rideandrepair, Bean Jr., JB7 and 3 others Thank this.
  5. 50WT
    50WT Road Train Member
    2,030
    17,459
    Dec 26, 2015
    10W40 ? I've always used ATF or straight 10W. But I haven't driven a Frightliner since the cabover days.
    RepoweredRookie and Rideandrepair Thank this.
  6. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    Atf or power steering fluid.
    Atf is cheaper though.
    Never heard of using a multi weight oil.
  7. AModelCat
    154,240
    IIRC Peterbilt used 15W-40 engine oil as factory fill for the power steering system.
  8. Big Road Skateboard
    5,686
    29,601
    May 2, 2021
    I agree with @AModelCat. PS pumps don't fail that often either.
    Were it mine, and I was keeping the truck, I'd personally replace both, and PS lines too.
    The last pump I bought was 300-325$ ish, gear box 6-900$ roughly.
    A good deduction and no worries about failures on the road
  9. JB7
    JB7 Medium Load Member
    644
    895
    Dec 13, 2022
    Laurel, MD
    Like @AModelCat states "Diagnose it before throwing parts at it. Its cheaper."
    It would not take a shop long to check out the front end. It could be something like a worn/binding joint in the steering shaft. Have the front end checked for worn/loose parts and grease everything. You mention a clunking noise which would be something other than the steering pump or box. Then move on to checking the hydraulics. If it has a belt driven pump make sure the pump is secure.
  10. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Yes. But most of the Frieghtliner’s I’ve seen all the way back to the White days called for GM type Dexron ATF. Unless the reservoir has a label saying motor oil I’d bet the fluid may be the problem. I agree.
  11. AModelCat
    154,240
    I was always told it didn't really matter which oil is used, just as long as the two aren't mixed. Don't really know how much truth there is to that statement though.
