steering column in a KW
Discussion in 'Kenworth Forum' started by rollin coal, Aug 21, 2014.
  1. rollin coal
    rollin coal Road Train Member
    13,087
    25,913
    Mar 29, 2008
    TN
    I've got an '03 with tilt/telescoping steer column. At my wits end with a steering issue. Anyone here ever tore into the column inside the cab and replaced those u-joints before? Not looking forward to this but it's the end of the line. Everything from the firewall down has checked out by experts. Had the king pins replaced a few months ago. They actually just finished tearing down and rebuilding the right one for a second time because it had some slight binding, with hindsight not enough to cause my issue. But they stood behind the work.
    Problem is I can't hold it in the road it's squirrelly. Been that way ever since the kingpins were done which is why I thought there was a problem there. They call it being pointy. You point the truck a direction and it wants to keep going that way. When you make a lane change one way or another and let go of the steering wheel your truck's steering should naturally center it's self. Mine doesn't. I have to always correct it back to center. Like it grabs when you veer to the left or right. Really hard to drive one like this.
    When I say everything has been checked, everything on the front end has literally been checked by first rate mechanics, I watched while they did most of it they showed me the what, why, and how. Tie rod ends all fine. Drag link ball joints good. Steering box, pitman arm - good. U'joints and slip shaft from the firewall to the box - check... wheels individually with the control rod taken off, you can grab the wheel with you hands and work it freely to the left and right on both sides of the truck - no binding in the new king pins. The only thing that wasn't checked is inside the column. They don't tear into columns. This one is on me, or Kenworth. I don't really care to take it to Kenworth. My understanding it's a labor intensive job you could practically replace the column for the labor involved. Column is very expensive. Sounds ridiculous for a $30 u-joint. Aggravating.
  3. dirthaller
    dirthaller Road Train Member
    1,015
    11,801
    Sep 22, 2011
    Coloratah
    How many degrees EXACTLY is your CASTER angle on each side? Many shops refuse to properly adjust caster.
    rollin coal Thanks this.
  4. rollin coal
    13,087
    25,913
    Mar 29, 2008
    TN
    I'll find out. Really disappointed they couldn't figure this one out. They said possible that the steering box could be whats making it bind. I put a reman TRW box on it several weeks ago. It's a #### money pit.
  5. rollin coal
    13,087
    25,913
    Mar 29, 2008
    TN
  6. dirthaller
    1,015
    11,801
    Sep 22, 2011
    Coloratah
    If your caster angle is too close to zero degrees, the truck will steer very easily but won't want to steer itself strait. If you have too much angle, the truck will have good highway manners but take both hands to make a turn. Cross caster (caster angle difference between right and left) is what most shops refuse to fix because it involves literally twisting the axle beam with a press. Most alignment techs refuse to adjust caster if the cross caster is within specs because if they adjust overall caster, they know it's unlikely that the CROSS will be easily adjusted back to specs.
  7. dirthaller
    1,015
    11,801
    Sep 22, 2011
    Coloratah
    if your old king pins were sloppy front to back instead of side to side that would explain why the problem started after the new pins.
  8. rollin coal
    13,087
    25,913
    Mar 29, 2008
    TN
    From what I understand they tear down the axle and send it out to a machine shop then reassemble when it gets back.
  9. rollin coal
    13,087
    25,913
    Mar 29, 2008
    TN
    I don't really think it's the column or the box. It's frustrating as hell. Just gonna bring it home and sleep on it. I've got an air leak to chase down in the meantime.
  10. 201
    201 Road Train Member
    12,058
    24,619
    Apr 16, 2014
    high plains colorado
    Hi rc, I replaced the u-joints in my 359 steering column, but there was a lot of play, binding sure sounds like steering box, although it could be a frozen or dry u joint. Can you grease them? What about drive axle alignment? Got enough grease on the 5th wheel?
  11. rollin coal
    13,087
    25,913
    Mar 29, 2008
    TN
    Yeah the 2 u-joints on the steer shaft between the fire wall and steer box are in good shape, I grease those with a half a shot every 5,500 miles or so. The slip joint is fine also and gets greased at the same interval. Axles were all 3 aligned after the kingpins were done by the same shop. Fifth wheel gets degreased and clean grease put on once a month plus add a little between that time span, it's never dry, and not just smear gritty grease from the edges.
