hi , I have some freeplay in the pittman arm on my t800. I am going to buy a new bolt and locknut to replace it . Im guessing the ft/b to be around 300? does that sound in the ballpark?
Thanks
steering box to pitman arm clamp torque?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hughjazz, May 3, 2019.
IIRC, on an international I worked on, it was 600 ft pounds, and it was a freaking allen head bolt. Try finding an allen wrench for use with a 3/4 drive torque wrench.
Need to know what gear? TRW or Shephard?
TRW pitch bolt is 300ft lbs and torque it on the nut, not the bolt. If it was loose and your not replacing both the gear and the arm, it will likely be loose again.Last edited: May 4, 2019
062 Thanks this. -
Thanks -
All steering gear sevice info is open to the public and online access.spsauerland Thanks this. -
Usually the Sheppard bolt has torque spec cast into the face of the head.
dustinbrock and Goodysnap Thank this. -
The free play is gone.. Next week I'll get a new bolt and lockwasher and set it up
Thanks guys
