Steering and Steer tire issues.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by robertedward, Jun 22, 2012.
  1. robertedward
    robertedward Bobtail Member
    Lithoniga, GA
    I have a 2001 Freightliner FLD120 and I'm having a steer tire issue. When I first bought the truck, I had virgin steer tires. In about 2 months of driving the truck, I noticed an unusual wear on booth steer tires. I thought I needed an alignment. After awhile the tires started showing indentions mainly on the right steer and A LOT of shimmying and wobbling while driving down the road. A mechanic told me it could be the shocks that might cause the tires to wear this way. so, I changed the shocks. Problem still persisted. I then changed the tires (steers) and got a three axle alignment. The truck rolled good for 100 miles but it felt like the tires weren't balanced. I took it back to the Tire shop and they checked the King Pins and found that they were bad. I changed the king pins and now the steering is very stiff when turning and it take a lot of effort to keep the truck on the road. I have to continuously correct my steering and if I over correct just a tad it pulls me to the that direction. Also, if I go over 65MPH, it shimmy's and wobbles like before I got the shocks, tires, alignment, and king pin done. I think I might need a new gearbox due to theres a lot of play in the steering but I'm not sure. After all of the work I've done to my truck why are the tires/steering still wobbling/shaking/shimmying? and why is the steering so tight?
    I appreciate any professional answers.
  3. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I would have someone inspect the front end first. Someone that knows and cares about what they are doing.
    Then I would try greasing the kingpins. May as well grease the entire front end.
    When did they do to align the truck? What was adjusted and what are the starting and final specs?
    What brand and model of tires are on the steer axle?
    Have the shackles and front mounts been inspected?
  4. robertedward
    Lithoniga, GA
    I'll get back to you with those answers.
    I did grease the entire front end and it's still tight.
  5. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    The front suspension has to be really wooped before it will cause tires to wear like that. Most of the time, tires wear like that because either they are junk J.A. Pan tires or they were never installed correctly and have been running out of round ever since. Once they are worn out of round and irregular your truck will always have a shimmy. Simply the tires are no longer round in shape and bounce erratically while rolling going down the road. Stop replacing parts you don't need to! Alignments and shocks are a good start, but if your new tires aren't installed properly it will always have a shimmy no matter what parts you throw at it. If your truck was somewhat stable before the king pins, and now it isn't, something went wrong with that job! Take it back! As for the shimmy, it is caused by the tire rolling out of round or out of balance! You can have tire to rim mis mount where the tire isn't properly seated centered. You can also have rim to hub mis mount where the rim is slightly off center to the hub and rolling oblong. To check this you would jack up the front end, pick the stones out of the steer tires, and spin them up. If they are out of round you will see the tire going up and down as it is spinning! Any good tire guy should know what I am talking about and be able to help you.
  6. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Also, each time the wheel is removed both mounting surfaces need to be cleaned. This would be the inside wheel surface and the matching part of the hub assembly.
  7. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Is this budd lug or hub pilot? Try a set of try balance centering pins last company used them and it helped a lot I would jack it up and disconnect steering linkage sounds fishy that its hard to steer after new king pins were installed sounds like they met be to tight
    Heavyd Thanks this.
  8. swap yankee
    swap yankee Bobtail Member
    When you had the alignment ,did they check for steer out,it's when u turn steering wheel max left then max right ,then back to center. alot of alignment shops don't do this test. It did wonders for the steer tires on trucks i've driven used to get cupping on inside edge of tires & truck used to pull right .the steer out test cured both issues.
  9. durallymax
    durallymax Medium Load Member
    318
    97
    Jan 30, 2011
    Just went through this on our 01 FLD. Freightliner shop , who wrve never had good luvk with,said the tire was chopped and shocks needed to.be changed. All of this was after independent mechanic said it was fine just a chopped tire (which was replaced with a new tire that ended up chopped later on) and an alignment. Replaced the chopped tire which wasn't.very old it bad and runs perfect on the truck its on now. The king pins felt loose to us from the start of the year long battle. Took it to the KW dealer who we've had great service with and the ended up doing the king pins. They had to rebore and sleeve the holes. We also balanced the tires.and the truck is now the smoothest and quietest it has ever been, which still isn't very quiet or smooth compared yo the other trucks but it is a freightliner.
    Goof luck.
