Steer tires on a truck different sizes
Discussion in 'Experienced Truckers' Advice' started by iquestionit, Aug 16, 2020.
  1. iquestionit
    iquestionit Bobtail Member
    Aug 16, 2020
    They tell me to fill out the book but never do anything I report.
    Air brakes over 10,000 pounds and they put Radial retreads on the front. One blew out like a 50cal the other day, while I was driving on a bridge. Tire was of Chinese descent with no DOT numbers.
    Now annuder truck I get into has different sizes and of course treads on the front, big gash in the sidewall. Now I can already hear you say DON"T DRIVE THE VEHICLE. To which I reply: most deaths from falling are from a six foot ladder. DON"T USE SIX FOOT LADDERS?
    Anyhew, is it legal to drive with different sizes on the front?
    jamespmack Thanks this.
  3. Suspect Zero
    Suspect Zero Road Train Member
    2,495
    9,414
    Oct 10, 2016
    Burbank, IL
    No, can't be recaps either.
    iquestionit Thanks this.
  4. okiedokie
    okiedokie Road Train Member
    11,668
    84,406
    Jun 13, 2011
    PNWET
    Not only No.....But hell No
    not4hire and iquestionit Thank this.
  5. AModelCat
    154,214
    What I'm seeing in 393.75 of the FMCSA regulations doesn't seem to say they're prohibited:
    Electronic Code of Federal Regulations (eCFR)
    Note it says "regrooved, recapped or retreaded" must not be used on the steer axle when refering to a bus. However, they only refer to "regrooved" tires when referring to a truck or tractor and only on tires rated above 4,920 lbs. Now I'm no lawyer so could somebody break that down?
  6. Long FLD
    Long FLD Road Train Member
    11,344
    45,646
    Mar 4, 2015
    As long as he’s not carrying passengers recaps are legal on the steer axle.
    As for the op’s question, I’d be more concerned with the gash in the sidewalk than if the tires are different sizes on each side.
  7. bad-luck
    bad-luck Road Train Member
    3,242
    5,937
    Nov 16, 2013
    Baltimore, Maryland
    Hold the press! Just so I understand are you saying they put retreads on the steer axle or on the drives?
  8. jamespmack
    213,256
    It is legal to run retreads on the steers, except on a bus. Its not advisable, but its legal.
    Lonesome, 25(2)+2, Dennixx and 5 others Thank this.
  9. Dennixx
    Dennixx Road Train Member
    4,418
    13,919
    Feb 13, 2010
    twin cities
    I would be most concerned why you'd be driving for someone who uses mismatched size/tread recaps on any position, especially a steer tire, unless it was a yard dog or a tractor doing field work...imho.
  10. REO6205
    REO6205 Road Train Member
    13,172
    60,482
    Feb 15, 2014
    California.
    Different size tires on a steering axle? Damaged tire on a steer axle? Recaps on a steer axle?
    Three strikes and out....I'd get away from that company. Now.
  11. TripleSix
    127,940
    Umm... what’s “annuder”?
    iquestionit, Suspect Zero and 8thnote Thank this.
  12. buzzarddriver
    3,507
    10,013
    Feb 1, 2011
    Dallas, TX
    Different size tires on the steer axle, bet that would be fun to try to keep straight on the road. Hard pull to the right or left.
    Suspect Zero Thanks this.
