Steer tire on drives?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dominick253, Mar 18, 2016.
  1. Dominick253
    Dominick253 Heavy Load Member
    746
    634
    Nov 19, 2015
    So I can into work one day, second shift left me with a totally flat tire off the rim. So the company has the tire guy come out. He puts on a steer tire in a drive position. Never see that before and was wondering why he did that. Thanks.
  3. Sho Nuff
    Sho Nuff Road Train Member
    1,175
    1,401
    Apr 9, 2015
    Was it the company that put the tire on, or road service?
    Either way, they probably had no recaps available, and decided to put the more expensive non recap tires on to get you going. Or if it was road service, they just wanted to charge you more. You can put nonrecaps on the drive, but you can't put recaps on the steering.
    Dominick253 Thanks this.
  4. Dominick253
    746
    634
    Nov 19, 2015
    Road service. This company doesn't do recaps. Goodyear's for the whole fleet. Looks retarded having a steer on the back though.
    Sho Nuff Thanks this.
  5. Knucklehead619
    Knucklehead619 Medium Load Member
    537
    591
    Mar 11, 2014
    Flyover Country
    My company does this a lot. Their reason is they want you to bring the truck or trailer with the new steer on it to a company shop where they'll put the correct used tire on. Then they pair it with another similar steer and put the pair on the next truck that needs a new set of steers.
    roadmap65 and Dominick253 Thank this.
  6. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Tread depth might have been closer to the rest of the axle than anything they had in runout. You don't want a 90% tire next to a 50% tire, because the taller tire ends up carrying the brunt of the load, and wears out much quicker.
  7. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    You can put recaps on the steering,just not very practical or smart.Can't put em' on a bus steering axle though
  8. Brandonpdx
    Brandonpdx Road Train Member
    4,184
    3,972
    Dec 27, 2007
    Elkhart, IN
    Actually I believe i read just recently that you aren't allowed to put recaps on truck steering axles either once you pass a certain weight threshold. Can't remember what it is but basically all class 8 truck tractors.
  9. Steve62
    Steve62 Light Load Member
    170
    98
    Mar 5, 2015
    Northern BC
    You can not use recaps on the steers!
  10. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    are you shure about that?I once had to put a worn out spare tire next to a nearly new one and it was the worn tire that wore out VERY fast.In fact it went so quick that after 150 miles no thread was left.
    If i remember correctly,the wear was worst when i was empty.
  11. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    I thought you could use a recap for a steer tire, but not on a bus.
