I don't believe there is a steel flat that would hold an arch with 86,520 sitting on a 5ft coil rack. Not bad for a 6 year old MAC.
Steel vs Aluminum flatbeds
Discussion in 'Flatbed Trucking Forum' started by DL550CAT, Mar 1, 2016.
Page 1 of 3
Zeviander, Cat sdp, Dominick253 and 1 other person Thank this.
No expert,.. but from what I have read, steel will flex more before it breaks. Aluminum is less forgiving. More brittle with little warning before something bad happens.
Not hating on Aluminum. My next trailer will be all aluminum. I wont be hauling 86k loads on it though.
HurstDominick253 and Klleetrucking Thank this. -
A aluminum trailer looks much better on 2 lane roads with a crown in center with the big 50+ coils than most steel frame trailers that will sway so bad that oncoming drivers will run off edge of road to keep from getting sideswiped with rubrail, my old alum. frame 1978 ravens 44ft. would stay even on the worst of roads.
Dominick253 and blairandgretchen Thank this. -
You have 86,000 on or your grossing 86,000?
Dominick253 and Hurst Thank this. -
That is the biggest roll that I can remember having on it. I'm not sure why it was so heavy they are usually lighter then the preprinted weight.Dominick253 and spax Thank this. -
Dominick253 and johndeere4020 Thank this. -
HurstDominick253 Thanks this. -
Is that 117k on 5 axles?
What kind of coil is that? I have never seen one like that.
I have a very hard time seeing you being able to permit 105k on 4 axles with a 42' bridge. They would have to give you 28k per axle if you had 12k on the steers.
Page 1 of 3
