Picking up a steel beam load, looked online and saw many drivers gotten killed with beams flying through the cab.
Feel okay about securing but after seeing this......
Anybody got some extra securement advice?
Steel beam loads killing lots of drivers, any advice?
Discussion in 'Flatbed Trucking Forum' started by Kenworth6969, Jun 22, 2021.
Blue jeans, Flat Earth Trucker, D.Tibbitt and 2 others Thank this.
Trip chains, chokers, and build a bulkhead with your dunnage.
Those guys had issues due to laziness, complacency, or poor training/understanding.Blue jeans, Stray_Dog, not4hire and 11 others Thank this. -
Drive it as you loaded with explosives.
BigCam9670, truckdad, not4hire and 9 others Thank this. -
It's not rocket science. Most guys are just in a hurry. Straps and chains. Then actually check them after you get down the road. The loads shift and chains/straps come loose. Just actually do your job and check them. Your life isn't worth the few extra minutes. Just my opinion here, but I believe the eld is to blame here. Too many folks are worried about the clock.
Edit: also, actually take the time and layer your securement. Don't be the guy that just throws a bunch of chains over the top.Daycabinit, truckdad, Roberts450 and 9 others Thank this. -
X chains in the front help alot as well. And do ur best to keep ur truck out of hard brake situations . keep securement tight at all times. If they are loading multiple layers its gonna take a couple trip checks to get them tight. Just check every 30 miles from shipper until they stop settling down... Other than that they are easy and fun to haul, one of my favorite loads to run. The long 50ft beams ride real nice since weight is destributed across the whole trailer evenly.... If you need help on securement dont be afraid to ask on here !
singlescrewshaker, farmerjohn64, not4hire and 10 others Thank this. -
What he said, put more Dunnage down, put the securement at the Dunnage as tight as possible, chains across tha front, each layer. Also put chains across the back. It will walk back. Don't go very far before you check the load. Check it again if any chains were loose You can put straps on the beams, on the front and rear you need chains.
TheLoadOut, shooter19802003, JoeyJunk and 2 others Thank this. -
Once you get loaded, put up some pics in the Flatbed Pics thread. People see it pretty quick, and can help you out almost in real time.
And if you lose the load through the cab and live, don't forget to post pics in the Hall of Shame!!JadeLove, Blue jeans, Speed_Drums and 9 others Thank this. -
Don't be afraid to ask one of the other drivers if it looks good. Refrain from putting the beam up to the cab. Those guys have loaded a few out.
Once you secure it properly don't forget to drive it responsibly. You can't control everything on the road but giving yourself some following distance does wonders for reducing hard braking...
God prefers Diesels and D.Tibbitt Thank this.
