Static shock
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dodgeram440rt, Jan 6, 2011.
  1. dodgeram440rt
    dodgeram440rt Heavy Load Member
    840
    601
    May 19, 2009
    Piqua, Ohio
    Is there anything I can do to dissapate the static electricity charge on my 09 Columbia? Every time I touch something, I get a little shock and it's getting really annoying. I touched my computer the other day and zapped it pretty good. Made it restart itself, but fortunately hasn't done it any harm.
  3. TruckrsWife
    TruckrsWife Significant Otter
    3,208
    41,399
    Aug 29, 2008
    God's Country, CA
    I don't know what you can do about the truck but you can apply lotion to your hands and it should eliminate the static so you won't shock yourself. LOL Year ago when I used to wear dresses a lot, my pantyhose would create static with my slip and was told to apply hand lotion to the pantyhose and it worked.
  4. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    I'm not sure if this will work on a truck but In Avaition they use Wire to dissapate the static. As well as every body pannel are linked together with wire then the trailing edges have wire that sticks out 6 inches or so when the electricty gets to the end of the wire it dissapates other wise aircrafts would fly untl the static built up enough and explode lol.
    I graduated from BTC for Avaition Technology...
    this is what they look like: there called Static Wicks
    American Trucker
    The Challenger Thanks this.
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If it is cold out you want to be holding your keys in your hands, works great as a way to relieve the static without getting zapped.
  6. Pfuse
    Pfuse Light Load Member
    119
    52
    Aug 18, 2006
    La Crosse, WI
    Buy a big sponge and soak it in some water. Put the sponge in front of your heater vent to bring the humidity inside your cab up. Higher humidity=less static electricity.
    123456 Thanks this.
  7. AXE
    AXE Road Train Member
    1,651
    688
    Jul 2, 2010
    Chandler, AZ
    I get the same thing when taking off my coat. What I do is remove one arm, ground myself to the seat frame then toss the jacket off, no more shock!
  8. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    on some tankers there are grounding wires on bumpers to let statics drain.
    And sometimes you are the static keeper. Becouse of syntetic ore woolen wear.
  10. dodgeram440rt
    840
    601
    May 19, 2009
    Piqua, Ohio
    I was wondering about static straps. That Hello Kitty one looks nice.... :biggrin_2556:
    I've seen some trucks with rubber bungees stuck thru the running boards or steps on their trucks and wondered if that was a way of eliminating static. Looking at my truck, it would be a little difficult to do that same thing, but if it actually works, I will find a way to do it.
    I always walk out to the truck with the keys in my hand, And when I stick it in the lock, there is a little blue zap. I can touch something and get a zap, then 5 minutes later, I'll get zapped again.
  11. Lilbit
    Lilbit Road Train Member
    16,583
    12,232
    Aug 4, 2008
    Let me check my logbook
    The bungies on the steps are generally for holding the fuel nozzle in place so you can fuel both sides of the truck at the same time.
    123456 Thanks this.
