Starting from a stop with a full load on a hill
Discussion in 'Experienced Truckers' Advice' started by truckingmechanic, Dec 6, 2015.
  1. truckingmechanic
    truckingmechanic Light Load Member
    63
    13
    Sep 4, 2015
    I just started driving and I am having some trouble starting from a stop, especially on a hill with a full load. I've been told to wait until you feel the engine start to pull then let off the brake and you should be good to go. Every time I do this the truck dies.I even let out the clutch very slowly like I am told to do. Should I be giving it some throttle at the same time? Any help about starting with a load or specifically starting on a hill with a load would be great.
    Thanks
    truckingmechanic
  3. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    What gear are you using?
    rabbiporkchop Thanks this.
  4. Mike2522
    Mike2522 Light Load Member
    52
    10
    Jun 28, 2015
    Illinois
    What gear are you trying to start off in?
  5. Justin Sane
    Justin Sane Light Load Member
    92
    69
    Aug 21, 2012
    Generally speaking, a diesel engine will start pulling a truck when the clutch pedal is let out without applying pressure on the throttle.
    With right foot on brake , start letting the clutch out; you will feel the engine start to pull the truck. Once the truck rolls a little, right foot off the brake and on the throttle.
    I assume with a heavy load starting uphill you are in first gear starting out. It takes practice and experience. When you have no load or a light load and on the flat; practice the foot maneuver: right foot brake, let out the clutch till it starts grabbing; right foot to throttle. Practice, practice; you'll be glad you did; the time may come when you have to stop going up a mountain pass.
    truckingmechanic Thanks this.
  6. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    You gotta give it some gas
    dca Thanks this.
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    If the hill is so steep that it won't take off without giving some throttle, then go ahead, but try not to slip the clutch too much. You're using low gear when taking off on a hill, right?
  8. chris887
    chris887 Medium Load Member
    545
    421
    Nov 11, 2015
    chicago
    Why did you post the exact same message in 2 forums?
  9. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    try second gear and give it a little throttle.. but don't take it to the floor
    feel it
  10. truckingmechanic
    63
    13
    Sep 4, 2015
    Thank you this will help a lot and yes when loaded and on a hill I start in first otherwise I start in third if I am not loaded
  11. truckingmechanic
    63
    13
    Sep 4, 2015
    First gear
