Stacked chassis securement?
Discussion in 'Intermodal Trucking Forum' started by windsmith, Jul 15, 2018.
  1. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I've been seeing some really good rates to move stacked chassis back to the ports. But they require me to provide chains / straps to secure them. Can anyone tell me what to expect if I decide to move some of these loads? What length of chains will I need, and how many? Will someone try to ding me for tire problems or damage that was done prior to my accepting and transporting the stack? Any other pitfalls that I need to watch out for?
    Darpen Thanks this.
  3. blairandgretchen
    13,212
    70,210
    Dec 9, 2011
    South west Missouri
    Is this 3 stacked on a flat bed, or a stack that is ON a chassis itself?
    On a flat I used about 8 straps with edge protection. 26-30’ straps - 4”.
  4. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    It's power only, so I'm expecting it to be a stack on a chassis.
  5. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    FWIW, I have 8 20' 3/8" grade 70 chains, 4 snap binders and 4 ratchet binders. And 2 30' 4" ratchet straps with chain extensions.
  6. blairandgretchen
    13,212
    70,210
    Dec 9, 2011
    South west Missouri
    2 securements in the first 10’ and 1 every 10’ thereafter. You could go 30’ chain, or 4” straps, or combination.
    Somebody here has hauled them like you’re proposing - will advise better.
    windsmith Thanks this.
  7. striker
    striker Road Train Member
    6,026
    6,439
    Aug 8, 2009
    Denver, Co
    Sometimes, they will come presecured to each other, I've seen them wrapped with chains/binders, multiple straps, and heavy duty banding material securing one to one and then two each other, with straps added.
  8. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    The load postings say that straps / chains are required.
    The other day I saw a set of 4 bound together with 2 crossed chains at each end, and 3 chains wrapped around the middle.
    bbechtel16 Thanks this.
  9. 51.50
    51.50 Heavy Load Member
    895
    1,942
    Jan 20, 2016
    Salem Oregon
    I chained them ( on a chassis ) the same as Windsmith except I put only 2 chains wrap in the center and the cross chains on both ends. I was hauling them to Oakland from Long Beach about 400 miles but did cross 3 scales.
    bbechtel16 and baha Thank this.
