Spread axle tires.
Discussion in 'Flatbed Trucking Forum' started by Peter_Bilt, Jul 11, 2021.
  1. Peter_Bilt
    Peter_Bilt Light Load Member
    84
    54
    Feb 18, 2017
    What tires do you use? Looking for a cheaper alternative than what I was using. Check out my thread in the reefer section for more in depth idocracy of the past few years I’ve had.
    singlescrewshaker and jamespmack Thank this.
  3. jamespmack
    213,256
    I run Michelin, but Continental has a good one. I dont run caps but some do. I would not recommend caps on front axle, esp if you have a rear dump. Some guys get away with caps on rear axle just fine.
    You do get what you pay for in tires.
    singlescrewshaker Thanks this.
  4. bad-luck
    bad-luck Road Train Member
    3,242
    5,937
    Nov 16, 2013
    Baltimore, Maryland
    General Tire makes a good 16 ply.
  5. mtntopbound
    mtntopbound Bobtail Member
    38
    71
    Sep 9, 2019
    Everywhere man
    I have gotten really good service out of roadmaster rm234 tires on spread axle flatbed. The last set I bought were in the $325 dollar range per tire.
  6. Peter_Bilt
    84
    54
    Feb 18, 2017
    What tire pressure do you guys run? I’m getting splitting in the sidewalls of what I currently run and have had a tire split on one tire on every set of four I have put on. Outside of that they seem to be good tires even with my messed up spread. They wear great and will last even longer once I square out my spread axle.
  7. jamespmack
    213,256
    LP 22.5 90psi year round covered wagon spread.
  8. shooter19802003
    5,654
    42,106
    Feb 8, 2010
    I run general at 105psi. I've got no complaints.
    singlescrewshaker and bad-luck Thank this.
