I will be driving a 26 foot Penske diesel rental truck from Spokane, Washington to Calgary Alberta in 5 days. I am wondering what the best route for this truck would be. Penske does not provide tire chains so if they are required we will have to stop and wait it out. In my own research I have chosen to go north on the 95 out of Coeur D'Alene, crossing the border at Easport. I would follow this route to Cranbrook and then head east on the 93 into Elko then continue on Highway 3 through Fernie, Sparwood, and Crowsnest pass. This is the part of the drive that concerns me. The weather report is not looking to horrible, and from my research it seems taking the transcanada highway or using i90 into central montana is worse roads. Do any trucks take the route I am thinking of going and are there ample stops to fuel up?
Thanks!
Spokane, WA to Calgary, AB BEST ROUTE?
Discussion in 'Experienced Truckers' Advice' started by dverzani, Jan 26, 2017.
That route is mandatory winter tires or chains (in BC), depending on the vehicle. If the truck is less than 27,000 kg (60,000 lbs) registered weight (which it no doubt is) and has marked winter or M&S tires with minimum 3.5 mm tread depth, you should be okay.
Otherwise, I would say that route is fine as that is the way I went from Calgary to ID, WA, OR and northern CA at all times of the year.
If you go that way, fuel is not a problem; you can top up in Bonners Ferry, and Cranbrook (there are other places, but typically smaller, so more expensive, until you get near/to Calgary). I would carry on east, past Highway 22 in AB (unless you prefer the slow, scenic, wildlife route) and go to Highway 2, then north to Calgary.
The entry to Canada via BC is generally a no-go if hauling produce however (probably doesn't apply in your case... just a general FYI).
Vehicles 5,000 kg to 27,000 kg GVW may use tires with the 3-peaked mountain and snowflake symbol or the M+S symbol in lieu of chains, if available.
- http://www2.gov.bc.ca/gov/content/t...er-tires-and-chains/winter-driving-commercial
Drivers must obey winter tire and chain signs throughout the province from October 1 to March 31.
Drivers failing to have vehicles properly equipped can be fined $109. Enforcement officers may prevent you from travelling if not properly equipped for road conditions or for safety reasons.
Sections of highways requiring winter tires or chains onboard are marked with roadside signs. For passenger vehicles, chains on summer tires are not an acceptable substitute for winter tires on signed highways.
Should you go beyond the signs without the proper equipment you may be turned around by RCMP, CVSE or another policing agency, and be subject to a fine.
Southern Interior Region Map
http://www2.gov.bc.ca/gov/content/t...asonal/winter-driving/winter-tires-and-chains
AModelCat Thanks this. -
Yes take us95 to Eastport then go straight past the scale that is route 3 to route 2 go north to Calgary. Fuel costs less in Bonners ferry I'd advise to fill up there. I don't think duty free sells fuel there.
@not4hire
What's the deal with no produce crossing there? Never heard that but never brought produce north through there either. I learned the hard way about Abbotsford one time...
Do they restrict produce to Coutts and the Blaine wa crossing? -
I love that route to Calgary. Beautiful time of the year to run it.
Beautiful route, WATCH for DEER and ELK between I90 and the border.
And neanderthal and bison once you cross over the line
fargonaz Thanks this. -
All they did for me was confiscate my Kershaw speed-safe for the crown.
