SPN 5394 FMI 17 Need help
Discussion in 'Volvo Forum' started by nasriza, Jun 19, 2018.
  1. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    So I need some input here this is something interesting, I keep having spn 5394 fmi 17 show up on two separate trucks i have tried everything and fixed and check all necessary components scr is performing perfect pressurizing dosing and all with no problems no issues from egr or egr coolers nox sensors were replaced in both cases the code comes up asks for a regen once it does the regen it disappears . I need to know if anyone ran across this before it's in a 13 volvo ved 13 @QUALITYTRUCK ,@Snailexpress
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    You have tough one to deal with.
  4. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    I fought this one on 2 different occasions. First time, just like yours, everything looked "good" Customer took to dealer and they replaced SCR box. He says it solved problem. Second time, all "good" again. I suggest SCR replacement. Customer does not believe me ($$) Takes to dealer. They replace SCR for $1500 more than my quote. Problem solved again. Sorry that I don't have more solid diagnostics for you. Toughest code to fix.
