SPN 520349 FMI 14
Discussion in 'Freightliner Forum' started by AlexD13, Mar 28, 2023.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hi Everyone, 2017 DD15 with 710k miles and got this code. Wondering if anyone has any experience with this. Thank you
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Usual cause is filters full of ash. Time for (2) new DPF"s. Make sure you remove soot sensor and clean with mineral spirits. Do a regen with laptop when done and reset ash accumulator.
    AlexD13 Thanks this.
  4. AlexD13
    298
    85
    Jun 13, 2016
    They were replaced in oct 2021.
  5. JB7
    JB7 Medium Load Member
    645
    895
    Dec 13, 2022
    Laurel, MD
    Here's a link for that code.
    4jciss.pdf (catbox.moe)
    QUALITYTRUCK and AlexD13 Thank this.
  6. AlexD13
    298
    85
    Jun 13, 2016
    We changed the soot sensor and 2 weeks later the same code pops back up.
  7. JB7
    645
    895
    Dec 13, 2022
    Laurel, MD
    Because the sensor is not the problem, only a symptom. Carefully read the procedures for the code. Make sure there are no other codes, if so repair those first. The procedures and QualityTruck in this thread both tell you that there is too much ash in the DPF. Needs to be cleaned or replaced. Does not matter that they were replaced in Oct 2021. Upstream issues will cause issues in the aftertreatment area. Should have the intercooler and piping/connections and exhaust smoke or pressure tested for leaks. You really need the data such as exhaust temp before the DPF and after etc. to see what is going on, if anything is not right. If you don't get to the root of the problem then the soot issue will keep coming back.
  8. AlexD13
    298
    85
    Jun 13, 2016
    Thank you so much! I will look into this sooner than later. Also was told It may be a software update with the emissions system
  9. AlexD13
    298
    85
    Jun 13, 2016
    The DPF's were cleaned 5 weeks ago and a software updated was done as well. The Same code returned. Any advise is appreciated So I pass it along to the mechanic.
  10. JB7
    645
    895
    Dec 13, 2022
    Laurel, MD
    So, you drove it for 5 weeks with no problems? Are you idling a lot? Was a regen done with laptop and the ash accumulator reset?
    The DOC is the first device in the after-treatment system. It is a flow through filter that contains precious metals to start the oxidation of hydrocarbons, carbon monoxide and unburned fuel and oil. Both the DOC and the DPF are honeycomb ceramic filters.
    Check and verify the simple inexpensive things first: air filter, check the intake and exhaust piping with either air or smoke. You need data from the system to see what the parameters are and if anything is off. There is a normal range for many parts of the aftertreatment system. Differential DPF pressure which is the difference between the inlet and outlet pressure of the DPF. Are the injectors running rich? NOx in and NOx out..... Maybe there is a problem with the 7th injector that is not setting a code. The engine may just be running rich and producing too many hydrocarbons.
    The DOC and SCR (not that the SCR which controls NOx is your problem) are similar to a catalytic converter in a car. Eventually the precious metals wear off and don't react with the exhaust gasses to do their job and eventually need to be replaced. If all the data checks out then I would suspect the DOC.
    Below is a good thread. DOC can/should be cleaned when the DPF is cleaned. With your 710k miles it's probably time for a one box.
    How long is the Detroit One-Box supposed to last? | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board (thetruckersreport.com)
  11. AlexD13
    298
    85
    Jun 13, 2016
    I am wondering If the mechanic pushing us to clean instead of checking for cracks internally in the dpf is the issue. Maybe a leaking dpf
